V6 Honda Fit Build - Page 3 - Honda-Tech
V6 Honda Fit Build
Old 06-20-2015, 05:30 PM   #51
PinkBatman's Avatar
Default Re: V6 Honda Fit Build
Quote:
Originally Posted by tony_2018 View Post
Are you also going to add power steering?
I would like to, have not looked at the wiring yet. Maybe it will just work out of the box.
PinkBatman is offline   Reply With Quote
Old 06-23-2015, 11:42 AM   #52
retroFIT's Avatar
Amazing work! Can't wait to see the finished product!
retroFIT is offline   Reply With Quote
Old 06-23-2015, 12:02 PM   #53
Quote:
+1!!!
Saw this first on FF.net
Amazing fab work going on here!!!
TPColgett is offline   Reply With Quote
Old 06-23-2015, 03:27 PM   #54
Original and awesome! Great work, can't wait to see it running.
DevinW is offline   Reply With Quote
Old 06-24-2015, 01:37 PM   #55
tony_2018's Avatar
Quote:
For a second I was going to type "yeah it would, just mount the pump" but than realize this was a fit.
tony_2018 is offline   Reply With Quote
Old 07-09-2015, 03:54 PM   #56
tony_2018's Avatar
OH no.....he's on vacation...no updates....
Old 07-12-2015, 09:13 PM   #57
PinkBatman's Avatar
Sorry, sorry. Been slacking pretty hard. I did deloom the l15 harness and started tracing some wires that I will need when I build my harness.
Old 07-15-2015, 08:25 AM   #58
bgangsta180's Avatar
Super sick build....this thing will rip when it's done....I will definitely be watching this till the end
bgangsta180 is offline   Reply With Quote
Old 07-15-2015, 06:35 PM   #59
tony_2018's Avatar
Its cool. You made tremendous prograss within a couple months. Its probably hot as **** outside.
Old 07-17-2015, 04:03 AM   #60
hondamark35's Avatar
I'm curious to know the amount of space that was added by building the tubular radiator support. how far did the radiator move from it's stock position?
hondamark35 is offline   Reply With Quote
Old 07-23-2015, 05:28 PM   #61
perfor.element's Avatar
very cool build!!
perfor.element is offline   Reply With Quote
Old 07-25-2015, 01:56 AM   #62
nice build, I wonder how it will handle.
notZylexSNL is offline   Reply With Quote
Old 08-12-2015, 12:55 AM   #63
PinkBatman's Avatar
Back in the saddle again. spent about the entirety of Sunday sorting out the test unit. Had to order a new crimper too.
This harness I got turns out to be in terrible shape, missing and broken connectors. Got another unit coming from one of the homies on facebook.
Wanted to test out the harness, but upon inspection it looks like the Fit has a returnless system. So I dragged the fuel pump out to investigate some solutions. Looks like there is a vent that will work great. Ordered a Grams 255lph and will convert it to a more traditional system.
Got some dope Sunchip dust incase you get the snackies
And sometimes you've gotta make a wonky tool to get stuff done.
Spent all of saturday working on this little project.
Old 08-12-2015, 03:10 AM   #64
claymore's Avatar
Dude you have some skills there. Most people on these boards would never tackle the rewiring themselves.
claymore is offline   Reply With Quote
Old 08-12-2015, 06:29 AM   #65
Freemananana's Avatar
After the fab work done, the wiring doesn't even seem out of the norm haha. Good job, definitely coming along. I am so excited to see how this thing handles with that big wonky motor up front.
Freemananana is offline   Reply With Quote
Old 08-16-2015, 08:46 PM   #66
tony_2018's Avatar
Hmm...that interesting. I didn't realize newer honda's don't come with a return system.
Old 08-17-2015, 11:53 PM   #67
PinkBatman's Avatar
Thanks guys
Took me off guard too, hope the plan to bypass that system.
Got that new pump installed. Grams 255 from the boys at Speedfactory.
Frankfuel setup now. Spring system is not functional but the intake is nice and low in the tank.
I was planning to try to start up the car tonight, unfortunately I cut the push lock fuel feed. So I had to put in an order for a bunch of AN stuff from Summit.
Old 08-23-2015, 12:32 AM   #68
PinkBatman's Avatar
Got a few parts of the harness sorted out, DLC is now working and the motor is turning over.
The biggest problem was the "solution" to connect the car to the J computer. I cut the plug from Fit ECU and was planning on using that to build the patch harness. Turns out that the pins were making inconsistent connections, once I bypassed that connector 12v was flowing like sweet strawberry wine.
That's probably for the best. I have a little set of knock off Deutsch Connectors and will put on an 8 pin tomorrow.
Here is the setup for the fuel lines too.
Old 08-23-2015, 07:32 AM   #69
Man your welds are pretty good! Love the project
Eight09 is offline   Reply With Quote
Old 08-24-2015, 03:11 AM   #70
claymore's Avatar
You do some awesome work. Can you let us know where you learned all these skills?
Old 08-24-2015, 01:31 PM   #71
PinkBatman's Avatar
Quote:
Lots of research and even more hanging out with my old man as a kid, just building bikes and goofing off.
Old 08-25-2015, 07:59 AM   #72
tony_2018's Avatar
Getting goosebumps.
Old 08-26-2015, 06:47 PM   #73
PinkBatman's Avatar
So this is how I spent the entire weekend.
Looking over diagrams trying to figure out why in the He-double-hockey-sticks
the fuel pump wouldn't fire. First problem was that the ECU didn't seem to be spitting out a +12v signal to fire the FPR. So I hunted for missing grounds, and blow fuses, and broken relays. LONG story short, A15 outputs a ground signal to fire the relay, once I figured that out the fuel pump still didn't fire. So once again I started pulling more fuses, and relays, and then spent about an hour looking for an inertia switch that was mentioned in the troubleshooting guide, a guide that was for a Civic, apparently, another thing that got overlooked in my mad dash to get this project busted out.
Another day of looking over the A plug for the Fit harness I noticed a sneaky little second relay that needs to be run to ground that should allow the pump to run, ground that lead and still nothing. Back to the diagnosing again, using the correct guide this time, do a few checks. Turns out at some point the lead from the ECU to the chassis got disconnected. Plug that back in and I hear that glorious fuel pumping sound.
Now the bay is a disaster from all the testing and wire swapping that happened, still haven't fired, but I think it should be pretty easy, maybe a missing ground or something silly like that.
Additionally here is the Fit A plug and its replacement.
Old 08-26-2015, 11:13 PM   #74
claymore's Avatar
Good stuff. It's great that you can track down and fix problems yourself. If a shop was doing it the price would be out of this world.
Old 08-26-2015, 11:39 PM   #75
PinkBatman's Avatar
First start!
Thank god I have free time!
Mini NSX Photoshoot skafia Honda / Acura 8 03-14-2016 12:13 PM
99 VSM Hatch Photoshoot | K20 | Mugen |Recaro|Spoon| CTR crazyjetsfan22 Honda / Acura 33 09-09-2015 09:03 AM
Hzrdus to your health | K Special SiR-G DC Honda / Acura 14 03-02-2015 11:30 AM
CMI SpringJam 2014 @ Sacramento CA DSDoneJimmy Honda / Acura 7 05-15-2014 04:42 AM
LHT Performance Meet 3/22/14 SiR-G DC Honda S2000 3 04-18-2014 05:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
