V6 Honda Fit Build - Honda-Tech
V6 Honda Fit Build
Old 03-05-2015, 11:18 PM   #1
PinkBatman's Avatar
Default V6 Honda Fit Build
I've been eyeballing Fits since they came out in the US, always hoped to get one, then last weekend my dreams came true!
So the plan is to drop in a J32a2 mated to an Accord 6 speed. This will eventually replace my all arounder CRX with a b20 vtec, except with AC and (hopefully) power steering.
Here is how she made it home after an 800 mile round trip
There are no Honda dealers around here, so while I was picking up this car I stopped at University Honda in Missoula to get a new key cut since I bought it without a key. Those guys were super helpful with everything and even fit me in late on a Friday. Unfortunately there was a short in the system so they couldn't program the transponder. They did cut me 2 keys and I will probably bypass that system anyway so that there will be no need for the stock ECU.
Rip it apart!
I don't know how much power these little things make, but with a v6 you gotta shoot for 300+
Boat anchor installed
There is a ton of room in this chassis compared to the EG chassis
Here is where I ended today
Drivers side mount tacked together, needs to be reworked
Passenger side could use some extra braces
And a little interior shot, wont see many of these in this build
PinkBatman is offline   Reply With Quote
Old 03-06-2015, 12:34 PM   #2
DVDr's Avatar
Default Re: V6 Honda Fit Build
Great project. Will be following the progress.
DVDr is offline   Reply With Quote
Old 03-06-2015, 02:14 PM   #3
Sanji
toyomatt84's Avatar
This is going to be pretty awesome!
toyomatt84 is offline   Reply With Quote
Old 03-07-2015, 09:01 PM   #4
Myxalplyx's Avatar
Ahh....I wasn't sure if you were going to make it over here on this board as well.
Myxalplyx is offline   Reply With Quote
Old 03-07-2015, 10:34 PM   #5
claymore's Avatar
Looks great so far. I will be following this build.
claymore is offline   Reply With Quote
Old 03-09-2015, 06:02 PM   #6
domoMKIV's Avatar
Too awesome not to follow!
domoMKIV is offline   Reply With Quote
Old 03-11-2015, 11:09 AM   #7
Wow. Looking forward to seeing more of this.
gawa is offline   Reply With Quote
Old 03-11-2015, 02:57 PM   #8
Superfly
Samuraij's Avatar
Wow. Can't wait to see how this turns out.
Samuraij is offline   Reply With Quote
Old 03-13-2015, 09:04 PM   #9
kingofbattle909's Avatar
IN (how do i make the letters bigger?) FOR THISS
kingofbattle909 is online now   Reply With Quote
Old 03-14-2015, 12:45 PM   #10
PinkBatman's Avatar
Thanks guys, love all the motivation the forums are giving me on this project!
Old 03-14-2015, 12:45 PM   #11
PinkBatman's Avatar
Here is the progress so far.
Got the new bumper cover, seems like a good fit so far. Doesn't have that blue tint that lots of these bumpers have, which is nice.
This is the new driver side mount, it's not pretty but it is functional. Will be adding some more structure to keep it rigid later on.
Finally able to lift up the beast!
Cut a little off the subframe to clear the trans, migd and sanded smooth it looks almost factory.
The start of the rear mount, added a ton of strength to the engine mount system.
You fit owners will notice that I removed the factory rear mount and welded a 1/4" plate over where it mounted. That was about a 2 hour job, but the new system was totally worth all that extra work. Lots of exhaust room on both sides of this piece.
Got a factory replacement set of headlights, went with the base versions, not really into shiny stuff.
Should have tons of room still in the bay.
This is where I am now stuck. We have used quite a few Tong Yang hoods, they all fit pretty alright, never perfect, but close enough.
This one is having a bunch of trouble though, the rear is 1/2" too low and about 1/4" too far back. I moved the hinges as far forward as they can go.
:confused:
I'm wondering if the hinges got bent in the accident, but they seem to be okay, no cracking paint or anything. Probably end up spacing them up and boring out the mount holes a bit to get it aligned. Can't build the front bumper until the hood and headlights get lined up.
Other than that I got the AC condenser and radiator ordered.
Old 03-14-2015, 06:29 PM   #12
darnizzle8805's Avatar
Sub'd
darnizzle8805 is offline   Reply With Quote
Old 03-15-2015, 12:14 AM   #13
claymore's Avatar
Good update keep them coming.
Old 03-16-2015, 10:23 AM   #14
PinkBatman's Avatar
Great news! After hours of fighting with some weird key problem the ignition now works.
Turns out part of the key was incorrectly cut, we found that out after completely removing the ignition and filing town one of the tumbler pins. Weird problem, glad that part is finally sorted out!
Old 03-16-2015, 12:05 PM   #15
tony_2018's Avatar
Dude....send that hood back for another...I know your penny pinching with the body parts and its cool and understandable BUT DAMN THAT FITMENT IS OFF.
tony_2018 is offline   Reply With Quote
Old 03-16-2015, 12:10 PM   #16
tony_2018's Avatar
Whats going on with the headers? I see you cut off two of the mounting holes from the header?
Old 03-16-2015, 02:44 PM   #17
PinkBatman's Avatar
Quote:
It's way closer now, we bent the hinges and all the gaps look WAY better. Should be okay to go now.
Not sure what part you are looking at. Might be the little pin at the top where they connect the two parts of the gasket.
Old 03-18-2015, 12:22 AM   #18
claymore's Avatar
Good news. What ECU are you using to control it?
Old 03-18-2015, 09:09 AM   #19
flatblack-h22's Avatar
Quote:
he's probably going to use the stock ecu, or AEM from his 4door civic..
i <3 you batman
flatblack-h22 is offline   Reply With Quote
Old 03-19-2015, 10:42 AM   #20
jlk16188's Avatar
subscribed!
jlk16188 is offline   Reply With Quote
Old 03-19-2015, 03:04 PM   #21
PinkBatman's Avatar
Quote:
i <3 you batman
I am definitely thinking about moving on from the sedan, I can use the Axles, trans and ECU from that car and part out the rest. If I get some free time tonight I might goof around with the wiring. Try to get the stock ECU to work first and then do that upgrade I showed you
Old 03-19-2015, 09:10 PM   #22
PinkBatman's Avatar
New progress this week. Not too much going on, been busy with other stuff.
This picture is going to make j32a.com pretty jelly
Got the panels lined up in an acceptable way, just had to get the 16" crescent on them hinges. You can see a little bend on the nose, not sure what's going on there, but I'm going to thrash on this car so it's not a big deal.
My old man had the clever idea on how to hold everything in place during assembly.
Old 03-24-2015, 11:38 AM   #23
Holy crap! This is amazing!
JoshTheJerk is offline   Reply With Quote
Old 03-24-2015, 08:10 PM   #24
PinkBatman's Avatar
Here are the shifter cables from the Accord vs the Fit. The connectors are all the some, but the box in the Accord is quite a bit longer.
Simply cut and rewelded them to the correct length.
Here is the RSX pedal that I got, doesn't look like the best solution.
And some folks asked me about the ground clearance so here is a shot of that.
Old 03-31-2015, 05:30 PM   #25
JDMH22HATCH's Avatar
Really cool build. Not sure how many miles are on the motor, but I would do a valve adjustment, egr port clean, and gaskets while the motor is out. That rear bank looks like it would be a bitch to get to in the future
JDMH22HATCH is offline   Reply With Quote
Mini NSX Photoshoot skafia Honda / Acura 8 03-14-2016 11:13 AM
99 VSM Hatch Photoshoot | K20 | Mugen |Recaro|Spoon| CTR crazyjetsfan22 Honda / Acura 33 09-09-2015 08:03 AM
⧀ SPRINT HART ℂℙ-ℝ 16X8 +20 / +25 5X114.3 ⧁ NO TRADES JDM_JNKY Southern California (Sales) 10 07-23-2015 07:50 AM
CA ⧀ SPRINT HART ℂℙ-ℝ 16X8 +20 / +25 5X114.3 ⧁ NO TRADES JDM_JNKY Wheels 5 07-20-2015 07:28 PM
GA 2003 RSX Type-S Championship White w/Black Interior krnseoulja Vehicles for sale 4 06-27-2014 07:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
