Honda Fit Honda Fit (Jazz)
So whos getting the hesitation/misfire????
Old 01-25-2010, 04:48 PM
DeDonDeRosa's Avatar
Default So whos getting the hesitation/misfire????
just curious to know if anyone else on this board has been getting a slight stuttering problem/light missfire.... happens at low rpms and gettin on the gas when merging on the highway... ohh its my wifes car and she has an 07 sport 5at... i know this has been talked about on fitfreak but wanna get some more opinons and what you guys have done? or takin it honda and what they have done?
Old 01-25-2010, 05:54 PM
E-AT_me's Avatar
Default Re: So whos getting the hesitation/misfire????
has not happened yet. 42k miles here.
Old 01-25-2010, 11:19 PM
claymore's Avatar
Very common problem. Just replace your sparking units.
Old 01-26-2010, 02:13 AM
macbuddy's Avatar
Default ...I'm not getting the hesitation/misfire!
DeDonDeRosa,
I did two things that got rid of my "hesitation/misfire":
1) I re-gapped the plugs to .035" (instead of the factory recommended .040-.051")
2) I brought the oil level up to spec, the V-Tec solenoid needs oil to operate (if your V-Tec solenoid is "fried," you will need a new one...~$150).
Hopefully these two suggestions will solve your problem. If they don't, then you might have to replace your coil packs at ~$250+ just for the parts (Ignition Coil - OEM Part Number 30520PWC003 - Price - $$61.62).
LMK what goes,
-macbuddy-
BTW, I am at 92K on the original plugs. I just checked the gap yesterday, and they are still where I gapped them. Here is what they look like at 92K if you are interested:
Old 01-28-2010, 09:48 AM
OK THANKS
Old 11-05-2010, 08:48 PM
SeaRose's Avatar
just want to share my story too...
this happened to my car a few weeks ago. it started to stumble/shake a little when it's accelerating on slight inclined road. First i thought it was just bad gas and the problem would go away if i try different gas, but it was not the case because it still shakes and even got worse after I tried different gas. Later i took my car to a repair shop and the mechanic said this could be a misfire and replaced new spark plugs in, now my car works fine like normal without the shaking problem.
Old 11-06-2010, 01:53 AM
E-AT_me's Avatar
at 63k my wife's 08 i think may be developing a slight mis.. i guess it would be about time to change the plugs. i'm thinking my EGR is clogged too. will be looking at it at the track today. i have plenty of time to kill.
Old 11-06-2010, 06:11 AM
yea i replaced the plugs in my wifes fit and it was fine for about a month then came back. really think it was the coils. but i traded it in anyway for a 2010 crv
Old 11-06-2010, 07:26 PM
torqen2k1's Avatar
Had a similar problem with my wifes fit when it had about 55k. Found out cyl 3 had a bad coil. $80 later no more misfire.
hatchlessrex
Honda CR-V & Element
08-17-2011 02:45 PM
5200BB6
11-02-2005 07:02 PM
ATS*Mark
09-08-2004 02:52 AM
crxY-49
10-26-2003 06:14 AM
Quick Reply: So whos getting the hesitation/misfire????
