Rear Drum Brakes?!
Rear Drum Brakes?!
I was just checking the specs on the Fit and it has drum brakes in the rear. This is probably to save weight but it's kind of a let down. I wonder how long it will take a company to offer the rear discs or if any other comapany like Spoon already have them available
Global Moderator
Re: Rear Drum Brakes?! (helmetDA)
Rear drums aren't such a bad thing.
They require adjustment and overheat sooner than disc brakes, but those are pretty much the only downsides. The Fit is a lightweight car and those who race lightweight EF's do not have any problems with rear drum setups.
Re: Rear Drum Brakes?! (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid »</TD></TR><TR><TD CLASS="quote">Rear drums aren't such a bad thing.
They require adjustment and overheat sooner than disc brakes, but those are pretty much the only downsides. The Fit is a lightweight car and those who race lightweight EF's do not have any problems with rear drum setups.</TD></TR></TABLE>
Considering the vast majority of braking is done with the fronts, I think they'll be just fine on the Fit being it's not a sports car.
I agree with you guys cause im gonna buy one for a daily driver. i would just feel a littler safer with four wheel discs
Re: (ZacCarter)
Rear discs yield better heat dissipation, fade resistance, water-shedding ability; all of which will help stopping distances. Albeit it usually isn't much, it may prevent you from colliding with a vehicle in front of you. Isn't that a safety advantage?
Yes, maybe in a car that weighs 2 times as much. There is a reason you only have to chang your rear pads every 50k miles or more, and thats because at least 80% of the braking is done with the front end of the system. Honda gave us 6 airbags and stuck us with rear drums, go figure.
Re: (ZacCarter)
There isn't going to a saftey risk with rear drums. I'd rather have the drums and save money on the car. If I were using it as a bonafide racecar, that'd be one thing. But for daily driving, drums are just fine. As stated above, the front wheels do 80% of the braking anyway.
Re: (Sushiboy)
True It would be different if the car were heavier then rear discs would be a must for better stability during hard braking, but since the Fit is small and light it really wouldn't need them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helmetDA »</TD></TR><TR><TD CLASS="quote">I agree with you guys cause im gonna buy one for a daily driver. i would just feel a littler safer with four wheel discs
marketing owns you
marketing owns you
Re: Rear Drum Brakes?! (EG6 SiRII)
I am an owner of a jazz (1.4 cvt-7). The car has 4 airbags but it has ventilated disc brakes behind. It also has 15" 185/55 tires and heated electric (closes with a button) with turn signal door mirrors.
