Honda Fit Honda Fit (Jazz)
JCrim's Honda GD3 (Road Racing Fit inside & Pics)
Old 08-05-2010, 07:37 AM
user 25438239's Avatar
Default JCrim's Honda GD3 (Road Racing Fit inside & Pics)
Hello all!
I'm JCrim and I have a fever and the only prescription is more Road Racing.
Everyone is asking for Pics and Specs. Here we go.
I drive a 2008 Honda Fit Sport. ^_^
-JDM K20A Type R (DC5 Type R)
-Brian Crower Valve Springs & Retainers
-NGK Laser Iridium Spark Plugs
-Hondata Intake Manifold Gasket
-Hasport 07-08 Fit K-Series Engine Mount Bracket Kit
-Hasport K-series Axles Honda Fit
-K-Tuned Idle Air Assist Delete
-Innovative/ Hybrid-Racing Billet Fit 85A Race Mount Kit
-Chasebays Custom Engine and Charge Harness
-Hybrid-Racing 70mm Throttle body
-Custom PRB Intake manifold port matched to 70mm
-Acura RDX 410 Injectors
-Hondata PRB KPro III
-RacePak Data Systems IQ3 RacePak
-RacePak Data Systems IQ3 to Hondata Interface V-Net cable
-EP3 Accelerator Pedal Assy
-EP3 Throttle Cable
-Hybrid Racing Autotensioning AC and power steering removal kit
-Hybrid-Racing Fuel Rail
-Hybrid-Racing (Russell) Fuel Pressure Gauge
-Hybrid-Racing Shifter Box
-Hybrid-Racing Shifter Cables
-Hybrid-Racing Cold Air Intake
-Hybrid Racing Breather Fiters
-Hybrid-Racing returnless fuel line kit
-Hybrid-Racing 1600CFM Electric Slim Fans
-BOSCH wide band O2 Sensor
-K-Tuned Thermostat Housing
-K-Tuned Upper Coolant Neck
-K-Tuned Coolant Hoses
-Password JDM Spark Plug Cover
-ClutchNet Stage 6 Racing E-Z Lock Sprung Hub Clutch Disc
-ClutchNet Stage 2 Pressure Plate
-Hasport Custom K20A to Honda Fit 3" Header
-Texas Chassis Works Custom Header back Burns SS 3" exhaust
-HushPower DBX 3" In/Out Muffler
-Van Meter Fabrications Hybrid-Racing Shifter to Honda Fit Box Assy
-Van Meter Fabrications Honda Fit Drive by cable conversion kit
-Van Meter Fabrications Radiator relocation kit
-Forged Racing Dual Core Aluminum Radiator
-Acura Integra GSR Modified Radiator Hoses
-Completely Gutted
-Removed the ABS system
-Removed every airbag and all airbag sensors and air bag inflation cartridges and all other unnecessary/ unwanted wiring
-949 Racing 6ul wheels, 15 X 8 et+36 rear and 15 X 9 et+36 front
-Nitto NT-01 225/45/15 front, Nitto NT-01 205/50/15 rear
-FastBrakes 2000 Acura Integra Type R all around brake conversion (12" rotors)
-FastBrakes Stailless Steel Brake lines
-Stoptech Slotted and Dimpled Rotors
-CarboTech XP10(front) XP8(rear) brake pads
-J's Racing Super Taikyu Chrome-moly Long Lug Nuts
-ARP Extended Studs
-949 racing Valve Stems (X2 per wheel)
-J's Racing Front and Rear tow hooks
-J's Racing front grill
-Custom Rogue Carbon Crowl Intake Scoop
-F1 Spec Type 3 Carbon Kevlar racing seat
-F1 Spec Type 2 Carbon Kevlar racing seat (for my larger passengers/ instructors)
-Nagisa Seat Rails (driver)
-Wedge Engineering seat bracket (passenger)
-Takata 6 Point Harnesses
-Skunk2 Pro C Coilovers with custom spring rates 12k front 10k rear
-PowerGrid custom Endlinks
-Alignment; Front = Camber -3.0° Toe = 0°
Rear = Camber -1.8° Toe = +0.17°
-Xenon Depot Bi Xenons HIDs 6500k and 3000k fogs
-Headlight Armor GT Racing Yellow Fog light covers
-J's Racing rear racing banner
-Rear wiper and motor delete
-all seat belts are removed and motors
-odyssey pc680 Battery
-Password JDM battery relocation kit
-All sound deadening has been removed from my car with dry ice, numatic chissel, and fire
-Nardi Torino Deep Corn 330mm steering wheel
-MER Custom 8 Point, tig welded cage
-The entire interior has been repainted to OEM Storm Silver Metalic after the cage installation
-Progress anti swap bar
-JDM Honda Access OEM Window Visors
-ALLVIEW Racers Mirror
-Longacre Mirror Bracket
-DIY carbon fiber stereo delete
-Mobil 1 synthetic 5w30
-GM syncromech friction modified tranny fluid
-ATE super blue brake fluid
-ATE super blue clutch fluid
-OEM Honda Coolant
-Red Line WaterWetter
-I/O Port Camera Mount
Video Links
Old 08-05-2010, 07:58 AM
New medicines
Abandoned Ship's Avatar
Default Re: JCrim's Honda GD3 (Road Racing Fit inside & Pics)
so you're getting some 949's as well? what happened to your weds?
those TR's are just obnoxious, i can't dig it. maybe if they were TE's, but then again.. maybe not.
Old 08-05-2010, 09:03 AM
ExplodingIbaLs's Avatar
Your fit looks good! Those wheels are blinding
Old 08-05-2010, 09:23 AM
haha thanks man
Old 08-06-2010, 08:58 PM
claymore's Avatar
Like the nice looking Fit. The wheels not so much.
Old 08-10-2010, 02:05 PM
Blue-Civic-Hybrid's Avatar
What kind of suspension are you running? Did you upgrade your front sway bar?
Old 09-06-2010, 10:04 AM
junktea1's Avatar
That was entertaining. You should get the camera mount that goes on the c-pillar bar.
Old 09-06-2010, 11:10 PM
contra's Avatar
Nice project.. Please post updates.
Old 09-07-2010, 01:11 PM
MattEFsedan's Avatar
Hey man, I saw you at autox in august, i was the novice in the tibby, cool fit
Old 09-12-2010, 06:53 PM
787-GD3's Avatar
Question why didn't u go with the Enkei RPF1's ? they are lighter..
Old 09-13-2010, 05:46 AM
Oh nice! yeah i dont really favor autoX at all.. it was my first time but *** working cones and ****. and cold run RR for life!!!
Thats like saying "why didnt you go with K24?, its faster"
Write me a check and Ill go with the played out RPF1s, k thanks
Will do! going to texas world speedway this friday again. ^_^
Old 09-13-2010, 07:05 AM
E-AT_me's Avatar
because 949's aren't "played out" either? it doesn't matter if they are "played out". "played out" stuff usually is "played out" because it works. both are great wheels. both are on about 25% or more of track cars i see. both work very well.
car looks good and seems to do well at HPDE's. i've had my wife's on track bone stock and it did me well. i look forward to seeing your updates.
Old 09-13-2010, 07:12 AM
I just have no love for RPF1s. 949 has my heart.
Old 10-06-2010, 05:33 AM
02OCT2010
The fit does it again. lots of passes.
this is 1 of 2 videos I shot. I pass the lambo in the 2nd vid
http://www.facebook.com/video/video.php?v=490437755800
enjoy ^_^
Old 10-06-2010, 06:34 AM
Razis's Avatar
you gotta road trip here to charleston so we can go do some road racing 1 weekend lol
Old 10-06-2010, 10:28 AM
heck yeah man. would be fun
Old 11-02-2010, 11:11 AM
Azcheron's Avatar
you know what would be awesome...turn off the ****ing music in the videos...thanks
Old 11-02-2010, 11:19 AM
You know what would be even more awesome? Track your car (cause you've owned plenty track worthy cars, which you can't make your mind up about so you post "help me decided! I want attention" threads) and stop hard parking, then post your opinion here.
Old 11-02-2010, 09:51 PM
claymore's Avatar
Jeeze you mean to say they left off the volume/mute button on your video player??????????????
Old 11-05-2010, 07:50 AM
tehondafrk's Avatar
Nice looking car man, I have an '09 and would love to get it out on a track, its stock minus wheels & tires but I bet I could have some fun.. What kind of brake pads are you using?
Old 11-05-2010, 11:15 AM
mcaro's Avatar
I lol'd
Old 11-17-2010, 07:45 AM
-Completely Gutted
-TRMotorsports C1 Wheels custom powder coated hyper orange 15X7 et+42
-Dunlop Direzza Sport Z1 Star Spec 195/50/15
-EBC Slotted and Dimpled Rotors
-Hawk HP Plus Brake Pads
-ARP Extended Studs
-DIY stock air box bore and heat wrapping
-Mugen Short Shifter
-H Fit shifter bushings
-Skunk2 shift ****
-F1 Spec Type R1 Carbon Kevlar racing seats
-Recaro Seat Rails
-Wedge Engineering seat brackets
-Alignment; Front = Camber -2.0 Toe = 0
Rear = Camber -1.5 Toe = 0
-Xenith Xenon Bi Xenons 6000k and 3000k fogs
-ETC throttle controller
-Odyssey 680 battery and mount kit
-All sound deadening has been removed from my car with dry ice.
-DME Header
-Megan Cat delete/ test pipe
-RS*R cat back exhaust
-J's Racing C pillar bar
-J's Racing Cross bars
-Cusco Rear Strut bar
-J's Racing roll center adjusters
Now heres some pics.
In road racing HPDE, before you can pass someone, they MUST give you the passing signal. See if you can spot them below. THE FIT IS GO!
Mini Cooper
Corvette C6 Z06
Mustang Shelby GT500
Pantera
Spec Miata
Camaro SS
lamborghini superleggera
Lotus Exige
Here's some older pics from Motor Sport Ranch, Cresson Texas. I was on bronze 16s..
Old 11-18-2010, 08:11 AM
junktea1's Avatar
How did you install the cross bars? Any major modifications?
Old 12-03-2010, 06:29 AM
Old 12-23-2010, 12:13 PM
Just a few updated pics before the fit gets caged ^_^
Quick Reply: JCrim's Honda GD3 (Road Racing Fit inside & Pics)
