Honda Fit Honda Fit (Jazz)
Jack Point for raising the Fit?
Old 12-23-2007, 01:12 PM
kwichang's Avatar
Default Jack Point for raising the Fit?
Changing the oil for the first time in my new Fit. I don't see any lift point (i.e. front crossmember) for my floor jack. Rear tow hook is present though
Where have you guys lifted up the front with a floor jack?...or am I just limited to lifting behind each front wheel (PITA).
I like to raise all four wheels off the ground and rotate tires when changing oil.
Thanks
Old 12-23-2007, 03:10 PM
* B A N N E D *
n1_egsex's Avatar
Default Re: Jack Point for raising the Fit? (kwichang)
i jack it up from the side
Old 12-23-2007, 03:49 PM
kwichang's Avatar
Default Re: Jack Point for raising the Fit? (n1_egsex)
Thanks! I thought that was the case, but didnt remove any of the plastic splashguards under the bumper/radiator to take a super close inspection.
Old 12-23-2007, 04:46 PM
07ssmfit916's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex &raquo;</TD></TR><TR><TD CLASS="quote">i jack it up from the side</TD></TR></TABLE>
me too..
but i have seen this before.. http://www.hondafitjazz.com/ma....HTML
Old 12-23-2007, 05:56 PM
kwichang's Avatar
Default Re: Jack Point for raising the Fit? (07ssmfit916)
Very cool 07ssmfit96! - bonus points for the Helm's manual diagram
Guess I should have taken off the splashguards and taken a closer look!
Old 12-24-2007, 04:01 AM
SuzukaBlueAP2's Avatar
I've used the rear tow hook to jack mine up before (not for an oil change obviously) and it worked well.
Maybe it's just my jack, but I can't comfortable get to that front point on the lower rad. support.
When doing an oil change I always raise the vehicle on the driver's side. Be sure to use jack stands while you are under the car.
Old 12-24-2007, 08:32 AM
Swaggylicious
$amGD3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07ssmfit916 &raquo;</TD></TR><TR><TD CLASS="quote">
me too..
actually on the usdms theres that bowl behind the tow hook and that's the jacking point for the back,for the front?who knows..lol...i cant even slide a jack that far under anymore
Old 12-24-2007, 08:34 AM
E-AT_me's Avatar
Default Re: Jack Point for raising the Fit? ($amGD3)
ramps.. atleast, that's what i use for my current cars. i haven't changed the oil in the fit yet. only 900 miles so far.
Old 12-24-2007, 05:49 PM
eL
eL's Avatar
Default Re: Jack Point for raising the Fit? (E-AT_me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-AT_me &raquo;</TD></TR><TR><TD CLASS="quote">ramps.. atleast, that's what i use for my current cars. i haven't changed the oil in the fit yet. only 900 miles so far. </TD></TR></TABLE>
My Sport wouldnt clear my ramps
Old 12-25-2007, 12:05 AM
Swaggylicious
$amGD3's Avatar
Default Re: Jack Point for raising the Fit? (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">
My Sport wouldnt clear my ramps </TD></TR></TABLE>srsly,i never owned a car that could go on those ramps my dad got me
Old 12-26-2007, 03:30 AM
E-AT_me's Avatar
i've got the small plastic rhino ramps, and even my lowered 86 fits on them. but i don't know about the fit. the front over-hang is a lot. if i set it up right, it should be able to go on them. (slightly sloped driveway. i can play with approach angles)
Old 12-27-2007, 11:28 AM
BMan88's Avatar
I use my Rhino ramps with my sport but, I have 4 2x4's that are stair-stepped to raise it high enough to clear the lip.
Old 12-30-2007, 04:06 PM
* B A N N E D *
teh cure's Avatar
Old 12-31-2007, 02:37 AM
NW Classic Honda's Avatar
Default Re: Jack Point for raising the Fit? (teh cure)
Takata LDS wheel ramps for lowered cars. The wheel ramps are made by out dated and recycled Takata harnesses, no joke! I need to buy me a set of these before they are all gone...
http://www.jhpusa.com/catalog/...d=733
efyou
10-24-2007 05:35 PM
HondaLvrJen
Honda Fit
17
06-28-2007 12:51 PM
Yellow Dragon
Honda Fit
14
04-21-2006 03:15 PM
budget
05-09-2005 04:37 PM
civicgl
01-07-2005 01:44 PM
Quick Reply: Jack Point for raising the Fit?
