how to install RED H emblem - Honda-Tech
Old 01-15-2008, 01:16 PM   #1
ekturbosi88's Avatar
Default how to install FIT type r emblem
how do u install the type r emblems on a fit, the front and back...... thanks alot
ekturbosi88 is offline   Reply With Quote
Old 01-15-2008, 08:28 PM   #2
c_mack9's Avatar
yeah its ep3/dc5 badges. they have 2 sided tape on the back.
c_mack9 is offline   Reply With Quote
Old 01-15-2008, 08:38 PM   #3
Default Re: (c_mack9)
thanks and how can i get the stock ones off, i dont want to damage anything.
Old 01-16-2008, 04:36 AM   #4
E-AT_me's Avatar
peel them off, then use WD40 to remove the adhesive. you can use WD40 and dental floss to get them off, too. works a little better than just peeling. make sure it's the waxed dental floss, though.
E-AT_me is offline   Reply With Quote
Old 01-16-2008, 09:09 AM   #5
Default Re: (E-AT_me)
ok thanks
Old 01-18-2008, 07:30 AM   #6
JRRR's Avatar
Default Re: how to install FIT type r emblem (jdmda7)
use a heat gun to heat up the emblem and then peel it off i used a credit card for mine but a heat gun is better...
JRRR is offline   Reply With Quote
Old 01-18-2008, 12:52 PM   #7
eL
eL's Avatar
Default Re: how to install FIT type r emblem (JRRR)
Quote:
I used a credit card and it worked for me.
eL is offline   Reply With Quote
Old 01-18-2008, 12:56 PM   #8
fitfreak3's Avatar
Default Re: how to install FIT type r emblem (eL)
Sorry EL but he really should learn to search http://www.honda-tech.com/zerothread?id=1920787
fitfreak3 is offline   Reply With Quote
Old 01-19-2008, 06:15 PM   #9
yeamans17's Avatar
Default Re: how to install FIT type r emblem (fitfreak3)
why would you use a heat gun on the stock emblems? theres no adhesive holding the stock H badges to the fit...
for the back look up behind the rear hatch handle on the outside and you'll see 2 tabs sticking in from the outside, break them off and the emblem comes off very easily
the front use a credit card and pry it out, the credit card won't harm the black grill material
yeamans17 is offline   Reply With Quote
Old 01-20-2008, 06:37 PM   #10
JRRR's Avatar
Default Re: how to install FIT type r emblem (yeamans17)
yeah well i used a heat gun to take the type r ones off, becuase there is no type r fit so i just put the stock ones back on cause i painted them black...they look pretty hard...
Old 01-22-2008, 08:34 PM   #11
yeamans17's Avatar
interesting, because a red h is a type r badge now?
Old 01-23-2008, 08:41 AM   #12
fitfreak3's Avatar
Quote:
I think he was referring to the FIT emblem and not the H emblem.
sorry i sound like a noob but does anyone know how to install jdm emblem on a 6gen? Njzfamous212 Honda Civic / Del Sol (1992 - 2000) 52 08-14-2013 08:16 PM
Are there holes under the Honda emblems? 94 Accord walker111 Honda Accord (1990 - 2002) 8 01-12-2007 05:17 PM
honda jazz emblem WESTI Honda Fit 6 09-19-2006 03:46 PM
emblem ITR77 Acura Integra Type-R 0 06-01-2004 07:05 AM
How To Take Off Your Emblems JUNIOR Honda / Acura 4 02-23-2002 05:50 PM
Tags
adhesive, badges, civic, emblam, emblem, fit, honda, install, installation, peeling, red, si, tabs, type, typer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
