TPMS On Canadian Fit's?
Does anyoine know if the Canadian Fit's come with Tire Pressure Monitoring Systems?
I don't remeber having the option >.< lol, but when I go to order rims it says I need wheel sensors.
TPMS is listed as standard on the US Honda website, but not listed at all on Honda.ca.
I'm 1/2 way across the country from my Fit right now or I would just go pop a tire off and check!
Any help would be great! thnx!!
Re: TPMS On Canadian Fit's? (logg_frogg)
normally you can tell by the stem. I can look at my stems and see they are much differant than non tpms
Re: TPMS On Canadian Fit's? (Iceycrx)
thnx man! I've only owned the Fit for 2 weeks and haven't had a chance to have a super close look at it yet! ...
Anyone have any more info? maybe even some pics of the sensors so I know what i'm looking for when I get back home??
I poked around on site here and found some more info. I know what I'm looking for now but i'm pretty positive that I do not have A TPMS system on my car as it is not required by law in Canada as far as I can tell.
Will post again in 3 days when I get home!
when you turn your ignition on, you should see the tmps light like the one of the picture on the left, and if you look at the valve stem just like iceycrx said, you can see a nut shape which you can take off with a 10mm deep socket. Just look for those, and you have tmps on your fit.
Re: TPMS On Canadian Fit's? (pepper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pepper »</TD></TR><TR><TD CLASS="quote"> you can see a nut shape which you can take off with a 10mm deep socket. </TD></TR></TABLE>
Should be a 12mm
Should be a 12mm
Re: TPMS On Canadian Fit's? (Groovinator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Groovinator »</TD></TR><TR><TD CLASS="quote">There are no TPMS on the Canadian fit. Unfortunatly the '09 models will have them.
I can now confirm this, I was home for the weekend and I definetly do not have TPMS
Thanks for all the help guys!
VTECAcuraGSR
12
08-22-2002 03:29 PM
