Honda Fit AC panel help - Honda-Tech
Old 05-26-2016, 11:11 PM   #1
Default Honda Fit AC panel help
Hello! I need help Identifying a problem with the AC connections. I pulled out the Dash to put in a custom housing for a double din radio. Upon pulling it out for the first time the main control for the AC popped out while still connected to the wires. I was able to find the copper piece that makes the **** get electrical contact to the wires but I am having trouble getting everything to work. Can someone help me out with this or get me to a link that give me more info on putting this part back together? any help would be appreciated. here's pics of what the situation is atm.
this is the connection behind the ****
view of panel from under dash
copper connection the flew off, note the back of the **** on the wires still
Dealership vaguely told me to replace the entire unit. I would really rather avoid that
ravrand is offline   Reply With Quote
Old 05-27-2016, 10:12 AM   #2
kp
kp's Avatar
Default Re: Honda Fit AC panel help
This doesn't look overly complicated, it looks like the copper plate fits in the white plastic housing. I see three tabs on the copper plate, and slotted holes in the white plastic. Line up the tabs with the slots in the plastic and it should fall into place. I see bumps on the copper plate which touch the contacts on the black plastic portion. It should fit in there one way only. The black plug portion should snap back into the white plastic (again, should be obvious which way).
Just try fitting things together, use your eyes and common sense to see that things "fall into place".
This is, of course assuming that nothing broke along the way, seeing as it looks like you really went full beans when taking this apart.
kp is offline   Reply With Quote
Old 05-28-2016, 06:48 PM   #3
okay it turns out that I needed a lot of pressure when sticking the pieces back together. I will mostly likely need to replace part 8 of the parts list. and yes I did go full retard on this.
b16b eg - axle and oil leak questions Yellow_gills Honda Civic / Del Sol (1992 - 2000) 6 06-10-2016 06:08 PM
CA FS: BBS R90 2-piece wheels and tires 4X100 17x7 rallyeredem2 Wheels 1 04-06-2016 11:20 PM
Teg parts dewey_civic Southern California (Sales) 2 01-23-2016 07:22 PM
Hey Guys and Gals Seebass1996 Introduce Yourself 0 12-16-2015 08:24 AM
Swapped intake manifold car stuck in limp mode HELP!!! niles.nemo Acura Integra 28 09-24-2015 05:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
