Headlight Removal? - Honda-Tech
Headlight Removal?
Old 06-14-2007, 01:24 PM   #1
Tight Fit's Avatar
Default Headlight Removal?
Alright i know im going to get flamed or whatever...but how the hell do you get the actual headlights out...does the bumper have to come off???
Last night i took the top 2 10mm out and there felt like there was something else holding the light in....i dunno
and is there any kind of diagram...YES ive searched
thanks for any positive help guys
Tight Fit is offline   Reply With Quote
Old 06-14-2007, 08:57 PM   #2
fitfreak3's Avatar
Default Re: Headlight Removal? (007 NHBP GD3)
I've never done it before, but I'm thinking it would be very similar to the civic. I would imgine there would be some plastic clips underneath the bumper, then 2 phillips screws on the sides of the bumper, a few clips on top of the bumper by the grill, and it should pull right off (There may be some clips you have to remove that hold the fender liner in place, maybe). Do this carefully so you don't scratch the bumper. Then you should have access to the 10mm bolts on the bottom that attatch the headlights and the bolts you've already removed on top and then you're done
fitfreak3 is offline   Reply With Quote
Old 06-14-2007, 11:12 PM   #3
07ssmfit916's Avatar
best i could find... this is off a 2002 manual... im not sure if its the same but if it isnt you can tell us
http://www.hondafitjazz.com/ma....HTML
and yeah according to this.. step one is remove the bumper =\
and for future reference... this is the link to the manual.. it says Honda Jazz Fit Service Manual (2002 onwards).. im sure its not useless to us here in the US
http://www.hondafitjazz.com/manual.htm
07ssmfit916 is offline   Reply With Quote
Old 06-15-2007, 04:33 AM   #4
Tight Fit's Avatar
Default Re: Headlight Removal? (07ssmfit916)
alright well thanks guys i guess wish me luck....im taking the bumper off this weekend
Old 06-15-2007, 09:31 AM   #5
JDMchris.com's Avatar
its real easy actually.
remove the bumber. then there are 4 bolts on each light. youll see when you remove the bumper.
JDMchris.com is offline   Reply With Quote
Old 06-15-2007, 09:31 AM   #6
Tight Fit's Avatar
Default Re: (JDMchris.com)
but the bumper is a bunch of clips or wha?
Old 06-15-2007, 01:50 PM   #7
the bumper has 2 screws on each wheel well. It has 5? clips up top that you pop off with a flathead screwdriver, then theres i think 7 underneath.
It only takes me about 5 min to take off everything.
O yea, the sides of the bumper clip in to underneath the headlight, when you pull the ends it sounds like cracking clips but dont worry its just unclipping.
Old 04-20-2008, 12:51 PM   #8
bfmed1961's Avatar
Default Re: Headlight Removal? (Tight Fit)
Okay i'm in the same boat as Tight Fit...i want to install my h.i.d. kit but dumbass honda makers don't make it easy...does anyone know of a website where i can see step by step pix of the front bumper/headlight removal for a '08 Fit Sport???????
bfmed1961 is offline   Reply With Quote
Old 04-20-2008, 08:23 PM   #9
SuzukaBlueAP2's Avatar
Default Re: Headlight Removal? (bfmed1961)
Quote:
Why should they?
Bumper removal is about one of the easiest things to do. I can yank the front and rear in under 10 minutes.
SuzukaBlueAP2 is offline   Reply With Quote
Condensation inside JDM front headlight. 01_ITR Acura Integra Type-R 4 10-06-2008 02:06 PM
keep getting condensation in headlights 361 accord Honda Accord (1990 - 2002) 5 01-26-2007 03:40 PM
my headlights r yellowish jli18 Honda Accord (1990 - 2002) 7 09-25-2006 09:55 AM
Headlight Swap doctasmith Honda Civic / Del Sol (1992 - 2000) 1 06-12-2004 11:56 AM
any freaking 98-01 headlights out there? gsrguy For Sale 9 01-31-2004 11:35 PM
Tags
08, 2007, bumer, bumper, clips, fit, gd3, headlight, headlights, honda, install, jazz, prelude, removal, remove, s2000, underneath
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
