DIY: 09 Honda Accord's Horn Upgrade
This is easy and can be done within 15 minutes. The 09 Accord's horn is much louder than the rinkydink Fit's horn. No longer where you'll be laughed at when they hear a freight train coming.:rotfl:
Materials needed:
- Flat head screwdriver
- 12mm Socket & Ratchet.
- 09 Accord's Horn (Part #38100-STK-A02)
- 15 Minutes.
First remove these 8 Clips using a flathead screw driver to get access to the stock horn.
Once you remove the panel, you have to remove these 2 clips in order to get to the 12mm bolt that's holding the horn.
Then remove the 12mm bolt
09 Accord's Horn vs. Stock 09 Fit
Put everything back together & voila, easiest upgrade ever.
Materials needed:
- 15 Minutes.
Dai_Ca_Vietnam_H22a4
02-09-2006 02:09 PM
