Alignment Problem need Fit owners opinion - Honda-Tech
Old 04-13-2007, 11:19 AM   #1
95egSi's Avatar
Default Alignment Problem need Fit owners opinion
I got my Fit Last week and I really love the car.
One thing that is bugging is that sometimes when I am driving on a straight road I feel that the steering wheel is ever so slightly leaning to the left.
I took it back to the dealership and went on a drive with an associate from their service department. We went for a ride and did the "6 second test", this is where you drive the car on the freeway at a steady speed, and if the car does not make a complete lane change in 6 seconds then the alighnment is fine.
The car passed the test. The car has a 12,000 mile warranty on the alignment so if I want I can have them throw it on the rack just to make sure.
So my question is do you guys notice the steering wheel tilt while you drive your fit?
I thought about it and figured that it can be caused by multiple issues:
1. Road Conditions (Roads are concaved for water dranage)
2. The car is front wheel drive
3. The car has no LSD
4. Me being paranoid because it is my first new car and I want everything to be perfect.
I would really appreciat any input.
Plus, if there are any Fit owners that would want to meet up around the Orange County area hit me up. I am thinking about setting up a Fit meet sometime in the future.
95egSi is offline   Reply With Quote
Old 04-13-2007, 11:31 AM   #2
JDMchris.com's Avatar
check the tire pressure. sometimes that can cause that as well.
JDMchris.com is offline   Reply With Quote
Old 04-13-2007, 11:32 AM   #3
Black Widow g2's Avatar
I took mine back because the wheel wasn't centered while I drove. They actually found the toe was too great in the rear. They adjusted it to be 'within spec' but the problem is they're close to being out of spec. I plan to be very particular with them and say I want each to read 0. I still have the steering wheel issue even on a flat road while driving a constant speed it isn't centered. It will pull to the left now instead of the right. It's very annoying to me. My 90 integra doesn't do it. There is no reason my Fit should.
Black Widow g2 is offline   Reply With Quote
Old 04-13-2007, 11:34 AM   #4
95egSi's Avatar
Default Re: (JDMchris.com)
Quote:
I did check the tire pressure. They are at the recommended 32 psi.
Old 04-13-2007, 12:42 PM   #5
daviddahlb's Avatar
Default Re: (Black Widow g2)
Quote:
You can't adjust toe or camber in the rear without some serious hardware.
If there is a pull to either side, it is probably from the front alignment.
If it is definitely the rear, then you could have bent suspension parts , or it was bad from the factory, because it is unadjustable in the rear.
daviddahlb is offline   Reply With Quote
Old 04-13-2007, 01:09 PM   #6
95egSi's Avatar
Default Re: (daviddahlb)
Do all the Fits out there have a perfectly centered steering wheel?
Or is this is common?
Old 04-13-2007, 01:47 PM   #7
would you like to see the sheet the dealer gave to me? On the spec sheet it says: The specifications for your vehicle are as follows: Front and rear toe measurement should be between -0.06 and 0.06. Your vehicle before alignment was -0.01 on the left front and -.04 on the right front. We adjusted to 0.00. The rear should be within 0.00 and 0.10. your vehicle measurement was .11 on the left and .03 on the right. We adjusted to .10 and .03. Your steering wheel was also adjusted back to specifications. Thank you for having your vehicle serviced by Stockton Honda.
If you think the dealership is lying, please let me know. I'm not a tech for good reason. I don't know how they work on this particular car. If the car has suspension flaws etc, then I sure need to have that issue addressed. I'd like to hear what you have to say.
EDIT: My bf's fit has a centered wheel. mine doesn't
Modified by Black Widow g2 at 3:00 PM 4/13/2007
Old 04-13-2007, 03:07 PM   #8
95egSi's Avatar
I'm thinking I need to take it back and have them look at it.
This really sucks. Not having a centered wheel honestly drives me nuts.
Anybody else have any input?
Old 04-13-2007, 07:07 PM   #9
Darth ModerVader
Padawan's Avatar
Default Re: (95egSi)
I think it's probably a combination of #1 and #4, with the addition of a slightly off-centre wheel, which is not terribly uncommon. It can be remedied on the alignment rack, but it doesn't necessarily indicate that something is askew with the alignment specs themselves.
Padawan is offline   Reply With Quote
Old 04-13-2007, 09:05 PM   #10
Chikubi's Avatar
Default Re: (Padawan)
Yeah, my wheel is centered as well, so best to go have it corrected.
Chikubi is offline   Reply With Quote
Old 04-14-2007, 12:43 AM   #11
95egSi's Avatar
Default Re: (Chikubi)
I appreciate all the input guys.
I got an appointment on monday to hopefully get this fixed.
I'll keep you guys posted.
Old 04-14-2007, 01:43 AM   #12
koolkevin1107's Avatar
seriously. I was afraid that when i lowered my car, the alignment was gonna be thrown off sooo badly but so many fit members said that they didnt' get it re-aligned. My car (now lowered) has a perfect steering wheel and there is no alignment problem. If its under warranty, just do it. OH and btw we have lots of meets in so-cal. U should join fitfreak.net if u havnt already. We have a meet this monday at norm reeves honda.
koolkevin1107 is offline   Reply With Quote
Old 04-14-2007, 07:35 AM   #13
Darth ModerVader
Padawan's Avatar
Default Re: (koolkevin1107)
Quote:
Have you actually had the alignment checked out? Just because the wheel is centred, or the car tracks straight, does not necessarily mean that the numbers are where they should be. I'd definitely suggest getting the car on the rack if you've lowered it.
DIY Alignment with 4 buckets, string and a tape measure joelmatt89 Honda Civic (2006 - 2015) 0 09-06-2016 11:39 AM
Steering wheel not aligned properly easyFOsheezy Acura Integra Type-R 4 08-25-2010 01:26 PM
Car sometimes wobbles left and right on freeway? milanoredgsr Acura Integra 6 02-28-2008 01:13 AM
extremely touchy steering after lowering nico.tico Honda Prelude 11 11-06-2007 05:30 PM
Traction Control problems Zani Honda Prelude 5 11-21-2005 01:56 PM
Tags
07, 2006, 2007, ailgnment, alignment, brakes, fit, honda, issues, norm, price, problem, problems, rear, reeves, sport, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
