AC compressor stays engaged, Low refrigerant - Honda-Tech
Old 07-30-2016, 10:31 AM   #1
Default AC compressor stays engaged, Low refrigerant
I'm working on my wife's 2013 Honda Fit's AC. It cools the car a little bit on cooler days but when it gets really hot outside, I.E. above ninety, we start to sweat in the car. I'm hoping it is just low on refrigerant but I want to be sure before I attempt to do any work on the car. I bought a cheapo ac recharge kit with the low side pressure gauge, and I get a pressure reading of a little under 45 PSI with an outside air temperature of 86. The compressor is engaged constantly, and the low side pressure doesn't move, it just stays around 45 after the car has been running for a few seconds. I haven't done any work to the car yet, and I am looking to confirm that it is just low on refrigerant. I was ASE certified for ac systems ten years ago but even then,I only worked on Semi Tractors. Is it safe to charge the ac and see if it cools the car? The pressure looks a little low to me but the compressor running all of the time seems strange since the common sign of low ac is a compressor that cycles constantly. Thanks
jachin99 is offline   Reply With Quote
Old 07-31-2016, 01:15 AM   #2
claymore's Avatar
Default Re: AC compressor stays engaged, Low refrigerant
Better find the leak first that missing refrigerant didn't just evaporate.
claymore is offline   Reply With Quote
Summer A/C Guide, How it Works, and When it Doesn't slowcivic2k Tech / Misc 138 09-15-2016 10:52 AM
Diagnosing expansion valve stuck open vs faulty compressor? brian0918 Tech / Misc 2 09-06-2016 11:22 PM
Replaced AC compressor. Low side is high, High side is low. RFEwing Honda Accord (1990 - 2002) 1 08-15-2016 11:20 AM
[FAQ] How-To: Charge your A/C air conditioner conditioning system at home drumminforev Honda Civic / Del Sol (1992 - 2000) 607 07-25-2016 07:42 PM
A/C Not Working Questions Hondaman56 Honda Civic / Del Sol (1992 - 2000) 4 07-12-2011 12:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
