3rd Gen (GK5), How-To: Fully disable traction and stability control (VSA/ESC) - Honda-Tech
Old 06-02-2016, 06:00 AM   #1
stealthpenguin's Avatar
Default 3rd Gen (GK5), How-To: Fully disable traction and stability control (VSA/ESC)
Try this at your own risk.
This is for third-generation GK5 Honda Fits.
The button on the left side of your lower dashboard is used to disable or defeat the traction and stability aids.
The manually only describes a process to partially disable traction and stability aids. I finally found a method to fully defeat traction and stability aids (ABS still functions).
Partially disable
Press to turn on, press again to turn off. This does not disable traction control in all instances.
Fully disable
1. Turn car on
2. Parking brake off
3. Press and hold brake pedal
4. Turn traction control on and off
5. Release brake pedal
6. Parking brake on
7. Turn traction control on and off
8. Press and hold brake pedal
9. Turn traction control on and off
10. Traction control light should be solid and another light blinking
Or, worded another way:
1. Turn traction control on/off with brake pedal on
2. Turn traction control on/off with parking brake on
3. Turn traction control on/off with brake pedal and parking brake on
4. Traction control light should be solid and another light blinking
stealthpenguin is offline   Reply With Quote
Cruise Control / Brake Pedal Switch 01CRVLX Honda Element & CR-V 1 07-01-2014 09:29 AM
how to disable TCS? hialeahzbg Honda Civic / Del Sol (1992 - 2000) 5 08-14-2009 11:16 AM
**5th Generation Prelude Honda Press Release** vinuneuro Honda Prelude 27 06-11-2008 04:46 PM
Killed: Ford Explorer turbojimmy General Discussion and Debate 40 02-15-2008 05:00 PM
traction control remove? 4 dr si 4drsi503 Honda Civic (2006 - 2015) 12 07-27-2007 01:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
