2008 Honda Fit Sport Headlight/turn signal switch - Honda-Tech
Old 06-30-2016, 07:36 AM   #1
Default 2008 Honda Fit Sport Headlight/turn signal switch
My low beams are out, but my high beams work. There was a recall on this and I took it to the dealership a couple years ago to have it replaced. I just recently took it back to the dealership and they said my bulbs were out.
I took it to my mechanic, he replaced the bulbs and the lights still won't come on. He said there is power to all 3 headlight bulb wires. He disconnected the combo switch, grounded the brown/yellow to main headlight relay, then grounded red/white wire combo switch and the lights worked.
He ordered a new switch. Here's the problem, he took the steering wheel covers off, but there isn't enough room to slide the old switch out due to the dashboard on the left side even with the steering wheel all the way up or down. Has anyone had any success replacing the switch?
Any help is appreciated.
Hillsmagee is offline   Reply With Quote
DRL Problem amaheux95 Honda Civic (2001 - 2005) 0 01-28-2017 07:56 PM
EM1 HID low beam not working on driver, high beam is. Toxin715 Honda Civic / Del Sol (1992 - 2000) 7 12-29-2016 05:55 AM
One outer headlight bulb very dim unclematt Acura RSX DC5 & Honda Civic EP3 4 09-01-2016 10:39 AM
1997 Civic Headlights Not Working. HondaGuy9 Lighting 1 04-17-2015 12:30 PM
How to you remove the brake switch? DCivic00 Honda Civic / Del Sol (1992 - 2000) 10 08-18-2007 10:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
