Honda Fit Honda Fit (Jazz)
2007 Honda Fit/Jazz A/C Relay Location!?!
Old 03-22-2015, 08:37 PM
savemyjazz's Avatar
Default 2007 Honda Fit/Jazz A/C Relay Location!?!
Fuse box complete
Full relay box
The relay in question
Hi all,
I'm new to the forum and a relative unknown when it comes to all things car related.
I recently had an issue where a current was passing through my A/C Relay even though the ignition was off. As a test the auto electrician removed the relay. I've since bought a replacement relay and wanted to install it myself however when I've looked in the under hood relay box there are no empty spaces, as is the case with the fuse box located under the steering wheel.
Can someone help me find where it goes as I am at a loss and after a few weeks of net trawling I can't find a single thing helping me out. It's definitely removed from somewhere within my car as the air con is not blowing any air at all.
Help me it's hot in Australia, even with the windows down!!!!!
Old 03-22-2015, 10:53 PM
claymore's Avatar
Default Re: 2007 Honda Fit/Jazz A/C Relay Location!?!
Look at the underside of the fuse box LID under the hood it has a diagram showing the locations of the relays. If I remember correctly it is one of the three large black ones on the top left side.
Old 03-22-2015, 10:58 PM
claymore's Avatar
Go here for the wiring diagram:
You must use IE to see the photos just click on the little grey boxes on the left.
A/C System Circuit Diagram (Without ETCS)
According to this there are three relays for the A/C and they are in the under hood fuse box like I said.
Old 03-23-2015, 10:39 AM
Global Moderator
tech8's Avatar
See attached image:
Old 03-23-2015, 11:21 AM
Global Moderator
tech8's Avatar
If your interior blower fan doesn't blow, then that may be the blower fan relay that was pulled. That relay is covered and not visible in your picture of the interior fuse/relay box. There are more relays inside.
Old 03-23-2015, 05:45 PM
savemyjazz's Avatar
Dear Claymore and Tech8,
Thank you so much for your help. I have located it, the shown spot in the under steering wheel fuse box, and I now have air con!
Thank goodness and thank you both so much again.
Geoff
Old 07-22-2018, 10:03 PM
Krisyadi's Avatar
Geoff
hi could you please tell me where exactly it is, because i think I’m having the same issue. Then fan still working even after i turn off the engine
Old 07-23-2018, 06:13 AM
Global Moderator
tech8's Avatar
I showed it as part of my post #4 above.
Old 07-23-2018, 06:52 PM
Krisyadi's Avatar
I tried to swap one of those relat but not solving the problems. Maybe it’s the fuses under the steering that is wrong. Because I used to open it and pressing some fuses, the issue was gone. But after few days it might loosen again and the issue seems to be appear again. But I don’t know which one is loose
Philip Smith
10-20-2021 04:46 PM
sam27
Honda CR-V & Element
03-10-2016 04:24 PM
kyleca1
10
07-03-2013 01:39 PM
Juniorhatch
Acura TL, RL & ZDX
04-21-2010 06:58 PM
stocker2shocker91
08-18-2007 10:52 PM
Quick Reply: 2007 Honda Fit/Jazz A/C Relay Location!?!
