2007 fit sport radio and dash turn off with AC on
My wifes 2007 Honda Fit sport has just started having a major issue. When driving at low speeds or idle and the AC is on and the compressor kicks in, every few times it causes the dash,radio, and car to turn off and then right back on in a split second. Sometimes just the radio turns off and then on. I got the battery tested it was fine, So I'm lost trying to figure this out. Any help would be apreciated.
Thanks
Thanks
Re: 2007 fit sport radio and dash turn off with AC on
The A/C coming on is a major draw on the electrical system and at low speed the alternator can't put out enough power instantly so the system crashes briefly when the power output is sufficient. I bet you haven't changed your coilpacks yet and have not adjusted your valves so the idle speed is very low also.
Actually I have changed coil packs in October of last year and back in June the Honda dealer checked the idle and also did a valve adjustments as well and check alternator and I replaced the battery .
muddmonky
07-09-2013 03:58 PM
Getsch
09-09-2012 08:50 AM
TurboTurtleGSR
05-27-2003 02:17 PM
