Honda CR-V & Element 2WD & 4WD Element & CR-V
Where is crankshaft position sensor located 01 CRV
Old 02-05-2013, 04:03 PM
razcob's Avatar
Default Where is crankshaft position sensor located 01 CRV
Where is the crankshaft position sensor located on 01 CRV?
How do you test this part?
Old 02-05-2013, 05:07 PM
LDForget's Avatar
Default Re: Where is crankshaft position sensor located 01 CRV
in the distributor.
Old 02-06-2013, 02:31 AM
razcob's Avatar
Originally Posted by LDForget
in the distributor.
Where is it in this bernardi parts diagram?
http://www.bernardiparts.com/SearchO...onda-crv-parts
Is there a sensor that attaches to the engine?
2001 crv lx 4wd
Old 02-06-2013, 03:20 AM
LDForget's Avatar
sorry i thought you said cam sensor. if i remember correctly, its on the top/rear of the crank pully, under the water pump. might be able to get it from the wheel well.
Old 02-06-2013, 03:26 AM
LDForget's Avatar
youve gotta pull off the pully to get to it. Youre going that far, you should change your timing belt and water pump while youre there if you havent already.
Old 02-07-2013, 12:27 PM
Technical Hero
HondaPartsHero's Avatar
Do you have a check engine light code?
Old 02-07-2013, 02:48 PM
blackaneseman's Avatar
http://torontohondaparts.com/PartsLi...ine&illid=9153
Located with the oil pump
canuck2
Honda Civic (2001 - 2005)
07-31-2019 05:12 PM
Masterl1nk
02-14-2016 06:22 AM
Aquafina
02-01-2008 02:00 PM
97CivicDad
02-02-2006 08:02 PM
Quick Reply: Where is crankshaft position sensor located 01 CRV
