Wheels for CR-V
Wheels for CR-V
I have a 2003 CR-V w/ 15" wheels (6.0 JJ 5 bolt w/205's). Will a 2004 accord 16" (8JJ 5 bolt) work? I'm concerned if the off set is correct. Also the 16" will take the 215 /225/& 235-65 will these all fit or what is the limit. This is a stock CR-V. Thanks for the comments if you can help!
Pap!
Pap!
Re: Wheels for CR-V
Pap!
Pap!
Regarding tire size, are you looking for closest to stock diameter or tallest possible?
Re: Wheels for CR-V
Thanks for the reply. I talked to honda and the accord wheels will fit but have a slight larger off set (wider stance) and was told it would work and improve stance. Also one might want to re-align after the swap.
Anyone else..your comment is welcome..please!
Pap
Pap
Re: Wheels for CR-V
205/70-15 normal size
215/65-16 2,68% larger than normal size, you need 215/60-16 0,54% smaller
225/65-16 4,63% larger than normal size, you need 225/60-16 1,26% larger
235/65-16 6,57% larger than normal size, you need 235/55-16 0,46% smaller
All % values mentioned are the diameter of the wheel
When you choose a bigger tire (diameter), your fuelconsumption goes up
Re: Wheels for CR-V
The 225/60 would prolly be your best bet tire wise...that is a super common size, lots of selection out there. At one time that size was going on a large portion of gm vehicles.
