Sam's 98 CR-V - HELP! Engine codes P0172 & P0170 - Honda-Tech
Old 10-12-2011, 03:05 PM   #1
Default Sam's 98 CR-V - HELP! Engine codes P0172 & P0170
Hi everyone. My 98 5-speed CR-V is giving me codes P0172 (fuel too rich) and P0170 (pending, fuel malfunction I think). The funny thing is that the codes come on about once a week, then the codes go away later that same day.
I've replaced the air filter, the fuel pressure regulator, cleaned the MAF sensor, and cleaned something else (forget).
Any thoughts?
Thanks!
staylor200 is offline   Reply With Quote
Old 10-12-2011, 05:05 PM   #2
Default Re: Sam's 98 CR-V - HELP! Engine codes P0172 & P0170
Any thoughts?
Thanks!
How did you manage to clean the MAF?There is no MAF on your CR-V.Anyway,start by checking the coolant sensor,if it reads correctly.It is the easy to do that first thing in the morning(you need the scanner ) and read the difference between IAT and ECT sensors.They should be within 2 degrees Celcius I think.Does your tune is up to date?If the coil,wires ,cap,rotor,spark plugs aren't delivering fire properly it might run reach.Check also the MAP sensor for proper readings.Oxygen sensor which is shorted to power could give that code also.But again scanner would tell you all the details.
exb18c1 is offline   Reply With Quote
Old 10-13-2011, 12:25 PM   #3
try some fuel injector cleaner! lucas is the best!
Thegnarles is offline   Reply With Quote
Help! P0172, P0302, P0170 r1racer Honda Prelude 3 04-10-2012 07:06 PM
Cel p0170, p0172, p0505 2ToneEM1 Honda Civic / Del Sol (1992 - 2000) 11 12-10-2007 04:52 AM
cel code p0170 help civictildeath Honda Civic / Del Sol (1992 - 2000) 1 09-25-2006 06:23 PM
Diagnostic codes P0170,P0172 jdlaurs Acura Integra 0 09-13-2006 09:50 AM
fuel trim malfunction & too rich MOVE OVER Acura Integra Type-R 5 08-20-2005 08:38 PM
Tags
2006, 32, 98, acura, code, codes, crv, element, honda, odb, p0170, p0172, pending, tl, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
