Honda CR-V & Element 2WD & 4WD Element & CR-V
Refilling coolant
Old 03-04-2015, 09:27 PM
Atauto's Avatar
Default Refilling coolant
I just finished draining and refilling the coolant on my 2001 CR-V yesterday. In the Haynes manual it should to use non-silicate coolant but I had to use what I had available at the time. Is it safe to use this chevron coolant low-silicate (picture) or should I replace it with coolant from the dealership?
Old 03-08-2015, 11:17 AM
nallerplys's Avatar
Default Re: Refilling coolant
i think you have nothing to worry about, but next time you drain your engine go for the honda coolant or a similar.
And next time you want to switch or repair anything look in the Haynes before you do it, not after
Old 03-08-2015, 07:17 PM
moun10goat's Avatar
Been running O'reilly's brand coolant after I did a radiator flush. No problems. I have had 4 different Hondas in my life, and I never once bought stealership coolant.
Old 03-09-2015, 03:31 PM
Atauto's Avatar
Thanks and I will.
Atauto's Avatar
Great to hear that you haven't had any problems!
GeneBEllis
05-10-2013 05:44 PM
lfunk11
Honda Civic (2001 - 2005)
01-16-2012 12:34 AM
kodarren
10-11-2006 06:39 PM
jvonb
12-02-2005 03:15 PM
Quick Reply: Refilling coolant
