Honda CR-V & Element 2WD & 4WD Element & CR-V
Passenger Side door Buzzing when Locked
Old 04-26-2012, 05:33 PM
01grnCRV's Avatar
Icon2 Passenger Side door Buzzing when Locked
I have a 2001 honda crv and it started a couple days ago when i lock the doors the passenger front door making a very loud buzzing noise. I was wondering if anyone else had similar problems? what it ended up being? how its fixed? and how much it costs to be fixed?
Old 04-26-2012, 07:16 PM
wgbm92's Avatar
Default Re: Passenger Side door Buzzing when Locked
More than likely the door lock actuator; an easy fix. Just take apart the door panel, and it should be located towards the inside kind of close to the latch. It might be a little tight to reach in and remove the screws, but it's pretty straight forward. Take out the actuator and disconnect it from the wire harness; install in reverse order. I don't know how exactly to remove it for a CRV, but this is more or less what the job involves.I just replaced the actuator in my Accord a few weeks ago.
Next time, use the search key. This has probably been covered multiple times.
Shadowsstrife
04-21-2017 06:51 PM
henryellison
08-27-2014 09:49 PM
draladriver
02-01-2014 01:55 PM
derekcentrico
08-09-2013 06:18 PM
chiggin
Honda Civic (2006 - 2015)
08-28-2007 11:31 AM
Quick Reply: Passenger Side door Buzzing when Locked
