Honda CR-V & Element 2WD & 4WD Element & CR-V
Oxygen sensor diagnosis
Old 11-24-2010, 03:04 PM
cruiseco's Avatar
Default Oxygen sensor diagnosis
1998 CR-V
My friend took her CR-V to the dealer for a check engine light coming on. Her paperwork says:
"Per inspection retrieved code P0135 HO2S (B1) Heater Failure, Rec.02 Sensor"
Does something in that specify the failure is with the primary or secondary sensor? From what I've seen online there are two sensors or am I mistaken?
She was quoted $360 for the sensor (just the parts -- about $550 total) which I thought was out of line but I'm also thinking that price might be to replace both. Is it just best practice to do both at once?
I'm hoping that the actual failure is to one of the sensors and the dealer just gave her incomplete information by not narrowing down the problem to a specific sensor.
Any thoughts? Thanks!
Old 11-24-2010, 04:58 PM
redbull-1's Avatar
Default Re: Oxygen sensor diagnosis
The trouble code P0135 narrows it to the primary heated oxygen sensor (bank 1, sensor 1). There is a primary and secondary sensor. Just replace the primary sensor as needed.
Is it an EX, LX (2 wheel drive), or LX (4 wheel drive)? Auto or manual transmission? Calif. model or non-Calif. model?
Old 11-24-2010, 05:18 PM
redbull-1's Avatar
Never mind on the trim level, etc., etc.
It looks like they all use the same Honda part number 36531-P3F-A01. Sometimes, different models use a different part. That's why I was first asking.
Honda list price is $273.20.
http://www.hondapartsnow.com/genuine...1-P3F-A01.html
Generally, the Honda OEM O2 sensors are actually Denso. At oxygensensors.com, it is $53.26.
http://www.oxygensensors.com/
Old 11-24-2010, 05:19 PM
cruiseco's Avatar
Thanks redbull. It's a CA car, 2wd (EX I believe) auto trans.
We'll get the sensor replaced right away -- her son has a friend that will probably do it for free. I've seen the Bosch sensors for about $75 which sounds a lot better.
Old 11-24-2010, 05:32 PM
redbull-1's Avatar
Denso is better than the Bosch for the Hondas, also it's only $53.26 at the oxygensensors.com link I have above. I bought from them a couple of times, they are reputable. Denso is OEM.
It seems right out in the open, so a 22mm wrench/oxygen socket or an adjustable wrench should do it. Make sure the friend puts the anti-seize coating on the threads (if it is not already coated) before he installs it; so, that if it ever needs replacement, it can come out a lot easier.
Old 11-24-2010, 05:44 PM
cruiseco's Avatar
Thanks again. That helps a bunch. I'll check out the Denso's. $20 is a good savinds. I doubt her son's friend could go over and get it done right away anyway so ordering it online shouldn't be a problem.
Dennin01
Acura TL, RL & ZDX
09-23-2018 07:17 AM
951parts
08-09-2012 11:43 AM
mar7pau
08-29-2010 10:34 AM
prostreetonline
07-10-2004 12:21 PM
Quick Reply: Oxygen sensor diagnosis
