Honda CR-V & Element 2WD & 4WD Element & CR-V
NEED HELP!!!! SWAPPED JDM B20 AND IT'S MISFIRING
Old 10-20-2014, 09:05 AM
FreshxJDM's Avatar
Icon2 NEED HELP!!!! SWAPPED JDM B20 AND IT'S MISFIRING
Hello H-T,
So my old motor seized, and I bought a JDM B20 high compression from JDM engine depot in NJ. Since the jdm b20 doesn't have the CKF, I did the by pass. IM not getting no CEL lights for the CKF, but I'm having a crazy misfire.
I honestly don't have any idea what's causing the misfire. Has anybody swapped their engine into a JDM b20, if so, did you run into any problems? Please HELP!!!
Old 10-20-2014, 09:19 AM
Ferio Wdm Edition
ferio-ichi3's Avatar
Default Re: NEED HELP!!!! SWAPPED JDM B20 AND IT'S MISFIRING
It csn be one or more of the following issues..
Bent valves
Bad rings
Bad spark plug
Bad spark plus wires
Bad dizzy(cap)
Bad injectors
No juice going to injector plugs
How you can solve.
Compression test
Swap plugs or wires
Clean dizzy contacts
Move injectors to another spot.
Old 10-20-2014, 03:08 PM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Yeah, over half of the engines I have gotten from JDM importers are usually pulled from over seas for a reason. Burnt valves, blown head gasket, bent valves, broken ringlands, timing jumped, smoked rings, the list goes on and on.
Old 10-20-2014, 04:13 PM
Fish Twig
tony_2018's Avatar
I replaced all gaskets, replaced oil pump to use the ckf sensor and dropped the motor in. Removed ecu fuse and backup fuse to keep the ecu from starting the car and cranked it until I saw oil in the head, placed fuses back in and let her rip.
Old 10-21-2014, 12:46 PM
FreshxJDM's Avatar
Thanks for the replies, i'll be checking all that.
I'm getting CODE P1129.
What can be causing that? does not having a CKF can cause that?
Old 10-21-2014, 01:58 PM
Fish Twig
tony_2018's Avatar
You know....googling the code tells you that you have an issue with *** sensor.
Old 10-21-2014, 02:21 PM
FreshxJDM's Avatar
Yes googling that says its the M A P sensor. But my question is, can this be caused by the CKF? I will be checking the bypass (spliced cables) over to make sure it's all well, also I will check the timing.
Old 10-21-2014, 04:38 PM
Technical Hero
HondaPartsHero's Avatar
Check to make sure you have the correct connector plugged into the MAP as it shares the same connector as the TPS.
Old 10-23-2014, 06:19 AM
FreshxJDM's Avatar
Thanks i'll look at this.
Old 10-23-2014, 06:22 AM
Retired Moderator
EsotericImage's Avatar
Swap the TPS and MAP and see what it does
Old 10-06-2015, 06:00 PM
bansell's Avatar
FreshxJDM, what was the end result on this? Did you get it running correctly? I am having someone pick up a b20B from JDM Engine Depot tomorrow..
Warhead955
10-20-2017 11:01 AM
portugino_69
08-09-2011 03:06 PM
smurf357
10-07-2009 06:24 PM
honda_ek9
03-16-2008 10:39 PM
TheMasterG
12-07-2001 06:34 AM
Quick Reply: NEED HELP!!!! SWAPPED JDM B20 AND IT'S MISFIRING
