NEED HELP !! swap k24a2 (tsx) in 02 crv - Honda-Tech
Old 02-26-2011, 05:47 AM   #1
Default NEED HELP !! swap k24a2 (tsx) in 02 crv
i everybody i wanna swap a k24a2 (tsx)to replace my k24a1 in my 02 4wd crv. if i got the computer and the wiring what i will need. maybe the manifold and stock oil pan. ill keep my 5 speed stock tranny. will it fit without any problem?? i need your knowledge thank
fardoche250 is offline   Reply With Quote
Old 02-26-2011, 07:32 AM   #2
Default Re: NEED HELP !! swap k24a2 (tsx) in 02 crv
a kpro will be on to good idea ??
Old 08-06-2016, 09:50 PM   #3
where did you get with this ?
looking to do same with my V
Eric Richmond is offline   Reply With Quote
Old 08-08-2016, 10:10 PM   #4
EJ8_Man's Avatar
Bolt the TSX head to your CRV block and tune with kpro. Google this its well documented
EJ8_Man is offline   Reply With Quote
Old 10-25-2016, 11:30 AM   #5
You can use a K tuner ecu, from an element or an accord. let us know how it goes.
asilversurfer1 is offline   Reply With Quote
Gen2 CR-V with a K24A1- what are my AFFORDABLE upgrade/swap options? Mr_Black K Series 4 11-05-2016 07:59 AM
K24a1 into tsx help? SELF MADE Acura TSX 1 06-22-2016 08:57 AM
1st ever AWD kswapped 1st gen crv w/parts list fitseries3 Honda Element & CR-V 10 03-28-2016 05:58 AM
K24A1 Flywheel weight EJ8_Man Honda Element & CR-V 2 12-06-2015 04:42 AM
k24 wire harness HELP k24_2Nasty Tech / Misc 0 02-18-2011 09:14 PM
Tags
2002, crv, element, engine, honda, k24a2, motor, oil, pan, rdx, replace, sale, swap, texas, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
