Honda CR-V & Element 2WD & 4WD Element & CR-V
How Do You Propely Remove the Driveshaft on the CRV
Old 11-28-2010, 12:26 PM
profishr's Avatar
Default How Do You Properly Remove the Driveshaft on the CRV
I need to swap out a trans and was wondering how exactly do you remove the drive shaft on my '01 Crv
Thanks for any help!
Old 11-28-2010, 03:27 PM
be professional
Targa250R's Avatar
Default Re: How Do You Propely Remove the Driveshaft on the CRV
Unbolt it.
Old 11-28-2010, 03:29 PM
profishr's Avatar
Originally Posted by Targa250R
Unbolt it.
From where at? Im not familiar with driveshafts. How many bolts should I be looking for and where will they be? Are they the 4 bolt heads that have several groves in them?
Thanks!
Old 11-28-2010, 07:07 PM
Hawkze_2.3's Avatar
Yes, there's 4 bolts. The ones right in front of the U-joint...
Old 11-28-2010, 08:56 PM
JDMDrifter05's Avatar
when i had to replace my trans 7,000mi ago all i did for the driveshaft was unbolt the 4 bolts on the transfer case/center diff. and let it hang down.
Old 11-29-2010, 10:51 AM
profishr's Avatar
do you know what size those 4 bolts are?
hondaautomotiveparts.com says "(12POINT 8X21)"
I tried a 10mm and 11 mm. 11 was too big and 10 too small it seems.
Old 11-29-2010, 10:56 AM
Deatschwerks's Avatar
It should be a 10mm or 12mm. Unless they've been changed by a previous owner/shop (doubtful).
Old 11-29-2010, 01:09 PM
be professional
Targa250R's Avatar
Uh, not to be offensive, but are you really prepared to swap a transmission? Unbolting the driveshaft is one of the simplest steps...
Old 11-30-2010, 03:50 PM
they should be 12 point 10mm.
Dateggy21
10-05-2008 07:06 PM
Rustynuts
08-01-2007 05:44 PM
phan
01-30-2006 11:52 AM
AaronJ
03-18-2005 03:35 PM
Nice_Dc2r
10-23-2003 10:41 AM
Quick Reply: How Do You Propely Remove the Driveshaft on the CRV
