Honda CR-V & Element 2WD & 4WD Element & CR-V
Crank pulley removal tricks
Old 03-10-2011, 05:14 PM
Tims Toy 500's Avatar
Default Crank pulley removal tricks
Timing belt change in a CR-V with B20Z: Does anyone know how to remove the crank pulley without Hondas $80.00 hex tool? (Not the spanner tool used on the early D15's)
Thanks!
Old 03-10-2011, 09:51 PM
turbodcivic510's Avatar
Default Re: Crank pulley removal tricks
pulley puller from like autozone or something>? or not enought room? and a ton of wd40
Old 03-11-2011, 05:26 AM
Hawkze_2.3's Avatar
Thanks!
You really should use the tool (or make one of your own if you have access to a welder). I believe Amazon has one for around $20.
Old 03-13-2011, 11:06 AM
Boosted Power's Avatar
I've never had to use any tool other than an impact gun, socket, extension, hammer and prybar for crank pulleys.
Old 03-15-2011, 05:49 AM
D50boy's Avatar
http://www.amazon.com/Powerbuilt-648...0196784&sr=8-1
$25, but worth it. You'll also need a couple of big breaker bars
BLKFLSH
04-10-2011 01:54 PM
sayanything
09-05-2010 04:28 PM
B!^A@
11-21-2006 10:04 AM
djnikko
19
04-24-2005 07:43 PM
Tommy_Gunns
07-18-2002 06:14 AM
Quick Reply: Crank pulley removal tricks
