Honda CR-V & Element 2WD & 4WD Element & CR-V
Cannt Start 2002 CRV (AWD)
Old 08-20-2012, 10:20 AM
autodriver's Avatar
Default Cannt Start 2002 CRV (AWD)
One evening after dinner in a restaurant, my 2002 CRV was a little bit hard to start and the idle was low. I had to give more gas to get it started. Then Check Engine light went on. Code was P0301 (Cylinder 1 Misfired). I erased it to see if it comes back. I also checked all sparkplugs and connections. They seem to be fine.
The next day, the CRV was also a little bit hard to start and idle was low until after I pushed some gas and warmed up for 10-20 seconds. Check Engine light came back. Error code was also P0301.
I replaced the car battery. The CRV started easily and Check Engine light turned off. Code Reader showed no error code.
The next day, the CRV was a little bit hard to start, but not as bad as before. No Check Engine light. Code Reader record no error. Couple of hours later, I cannot start the car. The engine just keep cranking.
The next day, I swapped with another new battery, but did not help. The CRV cranks but not enough power/strength to start. Code Reader shows no error code.
Old 11-09-2012, 06:36 AM
mnolt's Avatar
Default Re: Cannt Start 2002 CRV (AWD)
Coil Pack!
Old 11-09-2012, 07:31 AM
Technical Hero
HondaPartsHero's Avatar
I don't think one coil pack will cause a no start
vstone
06-01-2010 09:29 PM
wadafa
11
10-03-2002 03:49 PM
Leets
03-25-2002 08:41 PM
Quick Reply: Cannt Start 2002 CRV (AWD)
