Honda CR-V & Element 2WD & 4WD Element & CR-V
Brake squeak
Old 03-09-2015, 09:15 PM
Atauto's Avatar
Default Brake squeak
In my 2001 CR-V I'll take my foot off my brake pedal and it'll squeak. Has anybody else had this problem and would cleaning the drum brakes make a difference?
Old 03-10-2015, 03:16 PM
moun10goat's Avatar
Default Re: Brake squeak
When is the last time you had your brake pads and rotor checked/changed?
Old 03-11-2015, 11:28 PM
Atauto's Avatar
About 15,000 miles ago I put on a new set of pads / rotors. In the last couple of 1,000 miles it started making this sound.
Old 03-12-2015, 03:57 PM
natsuke's Avatar
Is the sound coming from the rear or front brakes. Sounds like the rear shoes are rubbing on the backing plate and is making the squeak noise. Take the drums off and put a bit of anti seize compound between the 3 touching places on the backing plate between the shoes.
Old 03-17-2015, 06:07 PM
Atauto's Avatar
As far as I can tell it's from the rear so I'll definitely try what you suggested.
Old 03-19-2015, 11:03 PM
Atauto's Avatar
Figured I would update this in case anybody else has this problem. What natsuke suggested made the noise go away
echang
09-14-2018 02:09 PM
CW_97_ITR
07-12-2004 11:14 AM
Web_Head
06-16-2004 10:02 AM
BrandonClaps
03-09-2003 10:25 PM
nsxmatt
03-25-2002 09:59 AM
Quick Reply: Brake squeak
