Best Spark Plugs - Honda-Tech
Best Spark Plugs
Old 06-04-2012, 05:53 PM   #1
Default Best Spark Plugs
Hey guys, Im looking at getting a new set of spark plugs and have read mixed reviews on the Bosch ones, and not many other reviews of the other brands. What do you guys use? Do you notice a significant difference over the stock ones?
Thanks!
ChalmersP is offline   Reply With Quote
Old 06-04-2012, 07:25 PM   #2
redbull-1's Avatar
Default Re: Best Spark Plugs
For the most part, you will not notice much difference unless your spark plugs were worn badly. What year and model is your car? The respective NGK plugs for the different Honda models and years work perfectly fine.
redbull-1 is offline   Reply With Quote
Old 06-04-2012, 08:34 PM   #3
qwrty's Avatar
NGKs for me.... all of our stock and modded cars uses these no issues eversince!
qwrty is offline   Reply With Quote
Old 06-05-2012, 05:45 AM   #4
jlk16188's Avatar
Quote:
agreed
jlk16188 is offline   Reply With Quote
Old 06-05-2012, 07:53 AM   #5
NGK Cables and plugss
DominicanFlow is offline   Reply With Quote
Old 06-05-2012, 08:13 AM   #6
NGK highly recommended
h22teggy95 is offline   Reply With Quote
Old 06-05-2012, 10:22 AM   #7
Alright! Im getting the impression that NGK is the way to go! What one though? Theyve got quite a few from what I see
Old 06-05-2012, 12:24 PM   #8
qwrty's Avatar
ive used ngk bkr6e/bkr7e on my 2 stock Vs... or go for the oem one! i think its posted on a
sticker under the hood or just search it online.. it should be cheap!
http://www.hondapartsnow.com/cr-v/98...~ca13s100.html
Old 06-07-2012, 06:02 PM   #9
Like above said, can't go wrong with NGK's in a Honda.
SuzukaBlueS2K is offline   Reply With Quote
Old 06-08-2012, 10:02 AM   #10
NGK!
Janet@bisimoto is offline   Reply With Quote
Old 06-09-2012, 12:30 AM   #11
platinum or iridium will last longer. however, any plug with the correct heat range and gap will perform just as well, but will wear sooner.
i go with the v-power's myself
el crapitan is offline   Reply With Quote
Can I find OEM spark plug at Advance Auto parts? Jaydeep Honda Civic (2001 - 2005) 1 05-23-2011 08:49 PM
ngk's or bosch platinum 4 spark plugs? CivicRaping Honda CRX / EF Civic (1988 - 1991) 9 03-08-2005 01:39 PM
Which Spark plugs ? B20-T Forced Induction 6 07-23-2002 10:59 PM
What plug gap should I use for 12:1 compression and which plugs? jonnybravo Acura Integra Type-R 11 03-20-2002 12:26 PM
Spark plug review... 976 Honda Prelude 7 09-27-2001 05:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
