Honda CR-V & Element 2WD & 4WD Element & CR-V
Any issues with slamming a awd 1st gen
Old 02-13-2013, 10:01 PM
1up_Andy's Avatar
Default Any issues with slamming a awd 1st gen
So i have a first gen (98) automatic awd crv and i want to slam it, is there any issues that i will run into? Also i am currently running a staggered setup 17x8/ 17x9 +35 all around wth 215/45/17 tires, any issues with running staggered wheels on a awd?
Old 02-13-2013, 10:31 PM
NZ-DB8R's Avatar
Default Re: Any issues with slamming a awd 1st gen
Have a search PLENTY of info about this as there are quite a few slammed CR-V
Old 02-14-2013, 03:36 AM
LDForget's Avatar
Depends what you consider slamming. I had to cut out all of my inner fender and bash in my frame rails just to steer.
Old 02-14-2013, 04:53 AM
1up_Andy's Avatar
I did serarch, i know about modding the fenders and all that, im asking about any issues with the awd system. I see tons of slammed CRVs but cant tell if they are awd or fwd ones
Old 02-14-2013, 06:21 AM
LDForget's Avatar
Mine was awd until I removed it. Awd system is fine
Old 02-14-2013, 12:09 PM
1up_Andy's Avatar
Was it hard to remove? I want to make mine just fwd since it will never go offroad or see snow anyway.
Old 02-14-2013, 01:53 PM
FeedBack159's Avatar
ive done it. no problem at all with the awd works fine.
Old 02-14-2013, 01:57 PM
LDForget's Avatar
remove driveshaft
remove differential
remove axles, but leave the stubs in the wheel hubs. they help keep the wheel bearing from seperating.
Old 02-14-2013, 06:08 PM
1up_Andy's Avatar
remove driveshaft
remove differential
Keep the awd trans in or do i have to swap in a FWD trans?
Old 02-14-2013, 09:48 PM
LDForget's Avatar
You can keep the awd trans. Won't hurt anything.
Old 02-15-2013, 05:02 AM
1up_Andy's Avatar
Awesome!! Thanks man
Old 02-17-2013, 11:24 AM
jdm_bones's Avatar
Sorry to thread jack, but in a similar situation, I have a 4wd crv 5 speed, and just installed a set of wheel that have off set, FRONT WHEELS: 7.5 x 17 with 32 Offset with 215/45R17 87W tire and
REAR WHEELS : 8.5 x 17 with 42 offset on 235/45R17 94W tire, my question is will it mess up my rear diff, because of the different size? also will have to install spacers in the rear wheel is to close to the upper control arm.
jdmWONG
07-29-2011 03:40 AM
shutta
03-11-2007 05:10 PM
budget
07-25-2006 08:26 AM
caliprelude3087
04-24-2005 12:59 AM
Quick Reply: Any issues with slamming a awd 1st gen
