99 CRV Slow Motion Build
#56
Re: 99 CRV Slow Motion Build
Thanks for sharing your progress with us.
With your current setup above, is it possible to raise the car back up to factory height or even beyond?
I imagine having at least 10" springs would be more ideal in that regard?
#57
The V looks great! I know you listed your suspension setup on the first page and I also read on the second page what you would change if you were to do it again.
Could you be kind enough to list the suspension build you would go with if you had the chance to redo it? Im looking for a similar drop (not slammed, but lowered and will eventually put a meatier tire on) The main thing I DO NOT want is a bouncy rear, so if you could recommend a rear/front spring rate I'd appreciate it.
Thank you!
Thank you!
#58
I couldn't get 9" springs so I ended up with 8" front and back. As it sets right now the front is high as it can go and the back is low as it goes. You'd have to have taller front springs to be able to lift it. 10" would probably be good for the front.
#59
Thank you!
Thank you!
#60
So you would use all the same components just with 10" front and 7" rear?
Didn't you says you would go another route with your shocks if you could do it again? Also what spring rate for the rear? Thanks alot
#61
I'm happy with the 350# springs I have in the back.
#63
I used this:
#64
Hey, Great looking CRV you got! I'm still amazed how many miles the car has and still running well! Good find.
I got a question regarding the stuck UCA, Couldn't you just throw a suspension bump stop in the inner fender beside the pinch weld? Or somehow attach it to the UCA ball joint? Yeah, you'll lose "some" suspension travel but at least it won't get stuck in there..
#65
Don't know. Maybe it would work. Nothing wrong with trying something new if you could figure it out.
#66
jkegarch
04-01-2010 06:04 AM
