Honda CR-V & Element 2WD & 4WD Element & CR-V
97 Cr-v electrical problem with horn
Old 10-17-2011, 07:24 AM
Dolewhite's Avatar
Default 97 Cr-v electrical problem with horn
Let me start by saying that I consider my knowledge of this car to be ever so slightly above the "gas is magic that makes the car go" level. but the horn has been out on the crv for about three months and its inspection time. I've removed one horn and tested it on the battery and its good, so I'm left hoping its a relay and not actual wire failure. I searched the threads and found the accord picture of the horn relay and location but after removing a good bit of the center console couldn't find a matching relay. This is my primary concern however, the front right window also doesn't role up, and the power locks are iffy at best, generally not working. if there is a picture of location and shape of the horn relay that would be golden, but any help or advice will be warmly recieved.
koreysDad
07-26-2013 06:00 PM
Habby
09-15-2012 05:57 AM
jayzeno
06-10-2012 04:32 AM
dootery
01-04-2011 09:38 AM
Quick Reply: 97 Cr-v electrical problem with horn
