98 Honda CRV AWD Transmission Issues. Help
Hello. My transmission was rebuild over a year ago,just recently the trans started to slip and not get into any gears,felt like it was in neutral..I changed the fluid,removed the shift solenoid ,cleaned it,put it back and the car ran fine, til it started slipping again. I also get a whining non stop noise coming from the transmission..any suggestions guys or should i start looking for another transmission? Thanks
Re: 98 Honda CRV AWD Transmission Issues. Help
you might wanna change atf fluids again... use oem! better yet check w/ your tranny
builder re this issue... thas how my other V got messed up when the former owner did
the atf change but didnt use oem fluid....
i used the honda atf with lucas, ill try to do another atf change..the car drove fine the day the trans started to slip so there was never any hint on the slippage previously..its like 1 second it was good than everything went downhill..
never mix any other fluid on your tranny.. its still "foreign" oil compared to atf-z1/dw1..
hopefully it could be fixed otherwise youll have to see your tranny specialist again!
just search the drain and fill method online, youll have to get 6 or more quarts of atf in
order to do this... i bought a LOT when i was fixing my tranny then... LOL!
good luck!
btw, check again solenoids (plugs,wire,filter..etc)
good luck!
good luck!
good luck!
who rebuilt it??? was there any warranty?
if it was done right you shouldnt have any problems right now...
sounds like the linings are gone.....
to be honest...i dont think drain and fill would solve your problem
the warranty was for a year only..and one thing i noticed was wen i removed the shift solenoid.i banged it on the wall to see if maybe there was any sh-t in there put it bak n it ran fine til the trans slipped again and a cel came on..
actually the non oem atf could be stuck on the torque converter... thats why at times it
may run good and would act up..visit your tranny builder so they could diagnose it again
for you.. make a deal w/ them since youve already used their service and your a returning
customer, they should take care of you! id suggest purging the whole tranny again and
use oem atf then observe it afterwards... hopefully it should do the work, if not the tranny
might need another check/rebuild...
good luck!
good luck!
Sounds like same issue I just had with my CRV..I thought it was the clutch..but ended up being the clutch master cylinder.
You could try that or the slave cylinder.
Good lucC bro..hope you get it figured out!
i have a tranny problem too...my v is automatic whenever i take off at high speeds or accelerate the gas it goes right to neutral or sometimes it will be on D4 and when i accelerate it will blink then end up in neutral(well in the middle cuz it shows like its on no gear...sometimes when it happens i hold the gear shifter on d4 nd it won't fade but it will blink off and on completely...idk what the hell is the problem..
Shiftless
12-27-2011 06:53 PM
