Honda CR-V & Element 2WD & 4WD Element & CR-V
98 CRV crank pulley wobble
Old 07-12-2013, 07:16 PM
swordofdoom's Avatar
Default 98 CRV crank pulley wobble
The B20 crank seems to wobble quite a bit, is this normal?
I have replaced the crank with a new crank and keyway pin but it still does it and its torqued to spec. Completely baffled. I checked the crank itself and everything seems to be smooth.
Old 07-13-2013, 04:34 AM
Sticker Bomb's Avatar
Default Re: 98 CRV crank pulley wobble
No it should not wobble. The crank could be bent right at the end when the pully sits on.
Old 07-13-2013, 03:20 PM
Damn great.........
Old 07-14-2013, 07:34 AM
FasterScooter's Avatar
Or the pulley may not be seated properly, possibly due to wear on the pulley. The other thing it could be is the pulley itself has been damaged.
Old 07-18-2013, 11:23 PM
Two pulleys and same result. I notice when I put the pulley on with the key you can slightly turn it 1 mm before it catches.
civikdude
02-13-2009 02:17 PM
DARKTEG_
08-13-2006 03:15 PM
asefi944
04-11-2005 02:26 PM
Quick Reply: 98 CRV crank pulley wobble
