Honda CR-V & Element 2WD & 4WD Element & CR-V
Need good info about 04 element
Old 05-13-2017, 10:09 AM
dracocrx's Avatar
Default Need good info about 04 element
Looking at buying a 04 ex element but it has a #2 misfire I did some research and found that a lot of them have a misfire in cylinder 2 but couldn't find any definite answers if it's common for the cylinder to lose compression or it's injector or coil problem if you have any info please share
Old 05-16-2017, 07:25 AM
Hamster65's Avatar
Default Re: Need good info about 04 element
The easiest way to find out if it's a coil is.........move the coil to a different spark plug and check to see if the misfire moves with it.
bobinyelm
Honda Civic (2001 - 2005)
08-02-2017 09:28 AM
ron spencer
18
07-20-2013 07:34 PM
aznkid4now
10-07-2012 04:44 PM
em2~b!tch
02-10-2010 12:14 PM
91ls-v
06-13-2004 01:35 PM
Quick Reply: Need good info about 04 element
