2003 honda crv obd2 question code error 1167
Hi I have a crv and I have a few obd2 o2 sensor problems.
http://www.obd-codes.com/trouble_codes/honda/
I checked this link and I have this two codes
P1166
Primary HO2S (No. 1) Heater System Electrical
P1167
So I read on other people's posts that I need to replace my o2 sensor. I replaced it today by using a brand new 61 dollar 4 wire bosch o2 sensor and it cleared one code. P1166 is gone. Yet, P1167 is still popping out every minute after I clear code. Any comments? the o2 sensor is brand new I do not know why there is a problem. I connected the wires like the diagram said and I dont know what else it could be.
P1167
this is all i see every 5 mins
P1166
P1167
P1167
be professional
Re: 2003 honda crv obd2 question code error 1167
The sensor you bought is no good. '02+ CR-Vs are very sensitive with the air:fuel ratio signal circuit and the heater circuit, so the system requires a specific oxygen sensor to work properly. A spliced-in universal heated sensor just won't provide the correct signal.
You need a Denso 234-9005. As of today, you can buy one for $101 with free shipping on Amazon.com.
I have a 2000 accord EX, 4 cyl auto, ulev. I had code P1164.
Bought a Denso 234-4620 sensor and cleared the code. The CEL came back this time with code P1167. Did I buy the wrong sensor?
I would appreciate any help or suggestions.
Thank you
raulg
Thank you
raulg
P1166
P1167
P1167
P1166
P1167
P1167
be professional
234-4620 is the primary sensor for the non-ULEV model. You need a 234-9025 for the ULEV.
my crv 2003 has a firing problem, it will refuse to change gear when try to fired, when check we discovered P1166 (Air/fuel ratio (A/F) sensor (sensor 1) heater system electrical problem A/F sensor heater , or heated oxgen sensor
pls assist to info me with diagram where the fault is .
924drb20
12-14-2010 10:36 AM
vtec25
03-14-2006 02:39 AM
