Honda CR-V & Element 2WD & 4WD Element & CR-V
2003 CRV Flashing D Drive P0700 Transmission Fault
Old 08-07-2015, 08:06 PM
buttercup's Avatar
Default 2003 CRV Flashing D Drive P0700 Transmission Fault
Hello,
I recently been receiving this concern with my 2003 CRV Flashing "D" Drive P0700 Transmission Fault. Ive been reading some topics regarding this issue but it relates towards with other fault codes. In this case, I am only receiving the one fault code P0700. Is there any Technical Bulletin from Honda relating this concern?
Any help would be appreciated.
Thank you
Old 08-08-2015, 06:53 AM
Fish Twig
tony_2018's Avatar
Default Re: 2003 CRV Flashing D Drive P0700 Transmission Fault
Did you identify what the code means?
Have you reset your ecu to see if it comes back?
Old 08-08-2015, 11:18 AM
buttercup's Avatar
The code is triggered by the transmission control module. This code is a permanent code. I have erased the code yesterday but I am concerned that this code will return. I have checked the fluid level which is good. I was wondering if anyone else has only experienced this code only. I know that this code P0700 is triggered due to a another transmission code.
Old 08-09-2015, 06:39 AM
Fish Twig
tony_2018's Avatar
I'm not understanding your comments that I put in bold. You need to list all codes that come up, yes code p0700 is a code particularly to the transmission but without the rest of the other codes then your only option is to bring it in to see whats wrong. Next time the CEL comes on pull all the codes.
Demambro
04-12-2017 10:11 AM
blkcivic310
07-13-2010 08:18 AM
Quick Reply: 2003 CRV Flashing D Drive P0700 Transmission Fault
