2002 CRV Serpentine Belt and Water Pump
I called Honda dealer to have Water Pump and Timing Belt and cam seal and crank seal service. I was told that 2002 CRV uese timing chain, not timing belt. No cam seal and crank seal need to service, different from Civic and Accord.
Question:
How many drive belts 2002 Honda CRV has? Is serpentine belt is the only one belt used in this CRV?
Does this CRV's cam seal and crank seal never leak?
If you have serviced your 2002-2006 CRV, how much did it cost you?
Question:
Re: 2002 CRV Serpentine Belt and Water Pump
Question:
Question:
You don't have to change out the Timing Chain until it starts making noise. Also for the water pump I would replace until it goes out as well. Cam seals wait until it starts leaking first. K24 Motor is pretty bullet proof. But if any one of those on the list needs to be change you might as well change everything else. How many miles are on your CRV?
I have 180k+ and never touched any of that yet.
It's not different from the Civics and Accords, later models 4 cylinders had timing chains. Six cylinder Accords still have timing belts.
Your CR-V had the one drive/serpentine belt.
Crazy3rdgen
12-22-2010 12:28 PM
zracer240
08-01-2005 10:07 AM
