2002 cr-v driver's window problem
I have two CR-V's and a accord. My 2002 drivers window won't come up. It goes down but not up. All other windows work fine. Checked fuses and wiring with power to down wire. Thought may be in motor and replaced. Same thing is happen with it. Ran wires trying to find broke spot or burnt places. Tried to jump hot wire to red/ black wire witch gave a heavy spark from wire with no action. When it happen the window was working fine than just stopped. Any idea where to go next.
Re: 2002 cr-v driver's window problem
http://cgi.ebay.com/ebaymotors/Sil-G...-/400220822643
I was trying to find a picture of it, its called Sil Glyde, I bought some at my local napa for 5 bucks. Put it in the window channel and it will greatly help your window go up and down. I did this for my accord windows which had the same problem, def worth the few bucks.
I have a similar problem with my 2000 model. The drivers window will not roll up or down. The passenger window will only roll down after replacing the motor. I believe it must be a problem with the master switch after doing like you did and checking the wires and the fuses. Strange problem that I was hoping someone had already found the fix for.
All others windows work fine. Drivers will go down but not up by motor. Thought it was motor so replaced. still nothing. Able to unhook window from regulator and slide up and down fine. Tried to jump power to red/back stripe wire with nothing happen. Red/blue has power when window is to go down. Could it be a the automatic relay?
where did you get the motor? you need to replace regulator. that's motor and whole assembly
Tru2Less
10
01-01-2008 06:38 PM
