2001 CRV problem filling up with gas, pump keeps stopping - Honda-Tech
Old 11-17-2011, 12:23 PM   #1
Default 2001 CRV problem filling up with gas, pump keeps stopping
I bought a 2001 CRV a month ago, 163k, Colorado driven with zero rust.
Every time I fill up with gas the pump keeps stopping. I have to hold the nozzle barely in the filler hole and fill it slowly to get any gas in it. Putting the nozzle in all the way and putting the pump handle on the highest flow like you normally would just stops almost instantly. Seems like a strange problem, and I searched and couldn't fine anything relevant. I've never had this issue with my 5 other Hondas.
Could the fuel filler neck be damaged somehow? Any other ideas?
thanks
tronic is offline   Reply With Quote
Old 11-18-2011, 04:07 PM   #2
TunerN00b's Avatar
Default Re: 2001 CRV problem filling up with gas, pump keeps stopping
The filler neck vent is clogged, plugged, etc...
The way the pump knows to shut off is when the fuel covers the neck vent, and air can no longer flow through it.
TunerN00b is offline   Reply With Quote
Old 11-25-2011, 06:56 AM   #3
I've looked through the fuel section of the 1400 page factory service manual, looked at the CRV, and I still have no idea where the "filler neck vent" would be.
Anybody know?
Old 11-25-2011, 07:02 AM   #4
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
there should be a tube running from near the top of the fuel filler, near where the gas goes in, down to the tank I think, it's part of the fuel filler neck, I would bet mud dauber nest in there, they love to crawl around fuel filler doors and into those
lostforawhile is offline   Reply With Quote
Old 11-25-2011, 07:09 AM   #5
it should look a lot like this, it could be a clog in the metal line or the short rubber hose at the end could be collapsed, if the metal tube is clogged, get a new tank gasket from Honda, pull the filler neck and run something through it, or compressed air etc, if it's the short rubber tube, get some fuel line, make sure it IS fuel line not heater hose, will be marked as such, and replace it
Old 11-25-2011, 09:34 AM   #6
By any chance is your check engine light on with an EVAP emissions code? i have seen bad canister vent shut valves cause this exact problem
Hondatech848 is offline   Reply With Quote
Old 11-28-2011, 10:28 AM   #7
there is also a Onboard Refueling Vapor Recovery valve (ORVR Valve for short) that captures fuel vapors during refueling. your problem may also be here
Old 12-04-2011, 07:24 PM   #8
I would also check the tube itself.
I have seen the ball inside tube to cause no fuel to be able to pass by into the tank.
Its like a check valve or anti-siphon.
andrew4g63 is offline   Reply With Quote
► Everything you need to know about autobody repair. ◄ harmonator84 Paint and Body 274 06-25-2015 05:27 PM
1990 Civic Si Gas Gauge Stuck but limits amount of gas into tank?? elmogs Honda CRX / EF Civic (1988 - 1991) 2 08-25-2011 09:45 AM
gas filler flap is missing hyung16 Honda Civic (2006 - 2015) 5 08-27-2010 09:51 PM
fuel gauge and fuel tank problems drwoody Honda Accord (1990 - 2002) 2 05-28-2010 05:52 PM
Fuel filler tube flapper SlowDown Honda Accord (1990 - 2002) 9 06-06-2007 07:51 PM
Tags
2004, car, civic, crv, fill, fillign, filling, fuel, gas, honda, keeops, pilot, problems, pump, recovery, shutting, stoping, stopping, system, vapor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
