2000 crv - rear differential fluid? - Honda-Tech
Old 07-12-2010, 12:57 PM   #1
Charlie Moua's Avatar
Default 2000 crv - rear differential fluid?
Okay the rear diff is starting to make some noise, so I figured it's time to change out the fluid. What kind of fluid can I use?
OEM - lucas - any gear oil at autozone?
how many quarts will I need to fill it up?
Thanks - Charlie
Charlie Moua is offline   Reply With Quote
Old 07-12-2010, 01:24 PM   #2
eghatch4sale's Avatar
Default Re: 2000 crv - rear differential fluid?
i would just go to the dealer for it i think it was dual pump 8.50 a quart
eghatch4sale is offline   Reply With Quote
Old 07-12-2010, 06:51 PM   #3
Duane_in_Japan's Avatar
It may be like gear lube, it may be like tranny fluid viscosity, get it from the dealer and some additive also, stabilizer of some sort for older diffs. Inspect for leaks, clean them up and be prepared for a regular inspection and refill if you have a leak.
Duane_in_Japan is offline   Reply With Quote
Old 07-17-2010, 07:16 PM   #4
oroblram's Avatar
oem dual pump 2 is good and quiet.
oroblram is offline   Reply With Quote
Old 07-17-2010, 10:12 PM   #5
qwrty's Avatar
use OEM fluids....
itll save you time and hassles in the future!
qwrty is offline   Reply With Quote
Old 07-17-2010, 11:34 PM   #6
Sordz's Avatar
Like everyone else said, OEM fluid for sure, buy 2 quarts it takes just over 1 to drain and fill. You should change it more often than what it sounds like you do, same with valve adjustment. Good luck
Sordz is offline   Reply With Quote
Old 07-17-2010, 11:57 PM   #7
Sordz, you have reached a milestone in your H-T post history, 69 posts, its time for you to upgrade to a real avatar and get rid of that noob looking thing there toughguy.
Old 09-09-2010, 07:50 PM   #8
johncrash's Avatar
dual pump is the fix if real bad you might have to do ittwice
johncrash is offline   Reply With Quote
EF sedan rear door handles Charlie Moua Want to Buy 1 12-23-2010 05:11 PM
FS: JDM DC2 REAR STRUT BAR Charlie7 For Sale 25 09-06-2006 10:01 AM
......d & b series power steering pumps.... (which are interchangeable ? ?) Charlie Moua Honda Civic / Del Sol (1992 - 2000) 5 02-21-2006 10:00 PM
Charlie Brown Kwanzaa C_H_A_D General Discussion and Debate 9 12-20-2005 05:00 PM
23mm JDM rear sway bar impressions... Willard Acura Integra Type-R 90 06-08-2005 02:48 PM
Tags
2000, 2002, 2010, crv, differential, fluid, forum, honda, insight, leak, noise, oil, rear, replace, s2000
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
