Honda CR-V & Element 2WD & 4WD Element & CR-V
1998 CR-V low beam headlight issue
Old 10-01-2016, 07:45 AM
pr1madona's Avatar
Icon5 1998 CR-V low beam headlight issue
A few days ago, my low beams stopped working. Only the parking lights come on. My high beams work just fine. I checked all the fuses for both low and high beam and the fuses are good. Checked the bulbs, filaments are still intact. I replaced the headlight switch last night, and they still do not work. Only other issue I have noticed is the my door ajar light on the dash also isn't working. Doubt that is related, but figured I would mention it. I looked at the fuse box under the hood to check if there was a relay that could be bad, but none of the relays say they are for headlights. Ideas?
Old 10-01-2016, 11:52 AM
Global Moderator
tech8's Avatar
Default Re: 1998 CR-V low beam headlight issue
A voltmeter would help you narrow down the possible issue.
With the headlight switch turned on, check the voltage at the low beam headlight sockets. If no power there, then check for power at the under-dash fuse no. 21 (10A) and no. 22 (10A). If there is power at the headlight sockets, then issue can be either ground wire(s) or faulty bulbs. They are dual filament bulbs.
Techvegas
12-12-2019 10:00 AM
Ekbrent
10-14-2011 02:44 AM
jtthwaits
03-05-2011 05:40 PM
johnnynguy3n
Honda S2000
03-27-2010 05:13 AM
chochocho
01-06-2005 09:49 AM
Quick Reply: 1998 CR-V low beam headlight issue
