1996 JDM CRV CEL and ABS codes
Hello, this is my first post but Ive been a forum lurker for some time. I finally have a problem I cant seem to figure out. I have a JDM model 1996 Honda CRV complete with the useless nav system and everything. I purchased her about 6 months ago. first thing I did was change the oil, transmission fluid and brake pads. The transmission fluid was very dirty but did not smell burnt. Has been running better ever since. Today I got a CEL light and yesterday i got an ABS light that went away. I jumped the OBD1 port and got the following codes:
CEL 03
ABS 5 short, 7 short, 5 long 1 short?
The CEL code 03 is for the MAP sensor, I will try to unplug and replug that one in. The ABS codes I am having trouble reading. I took a video if anyone can help me count. I have been using this thread as a guide:
https://honda-tech.com/forums/acura-...s-here-978933/
94-97 ABS CODES (thanks to JimBlake):
You pull these codes the same way you pull check-engine codes, but it's the ABS light that's blinking. Here's the sequence...
Insert the jumper, then turn on the key.
Long (2sec.) flash - long (2sec.) pause - this isn't the code yet.
Short flashes for the first digit of the code - 1sec. pause - short flashes for the 2nd digit.
Long (5-second) pause, then the next code.
(94-97) ABS DTCs...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
There's NO long flashes, it's all short flashes with short & long pauses in between.
That ABS code guide states that there are only short flashes but I clearly see long flashes for what looks like the 3rd code. Maybe JDM is different?
CEL 03
(94-97) ABS DTCs...
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
