Honda CR-V & Element 2WD & 4WD Element & CR-V
08 CR-V ABS Trouble
Old 11-01-2015, 12:11 AM
Sikke68's Avatar
Default 08 CR-V ABS Trouble
Hi everyone,
I'm a owner of a 2008 CR-V 2,0 i 4wd, at aprox. 4 weeks ago my ABS, VSA, TSA lights plus warning triangle on the dash startet, diagnostic says it is a faulty Rear Left ABS sensor. Checked the sensor with an multimeter and it was bad, low Ohm and did not produced any voltage when i rotated the wheel.
Since the local Honda dealer's would charge me between 350-500 USD for sensor only.... i bought an aftermarket one with same part no 57475-SXS, and now the lights go off as normal, but when i reach above aprox. 40 kmh it starts again.
I have tried a second sensor, same symptoms.
Checked those two new sensor and they have around 400 kohm resistance, then i checked my rear right sensor and one in the front and they both measured around 6,6 Mohm..... Does anyone know what the value of an original sensor should be or what Honda says the value should be?
Thanks
buzzby
Suspension & Brakes
01-01-2018 08:47 AM
swenceslaoe
02-18-2016 09:19 PM
Hondaman56
09-21-2012 07:44 PM
johnjk
08-07-2012 03:59 AM
Quick Reply: 08 CR-V ABS Trouble
