Honda CR-V & Element 2WD & 4WD Element & CR-V
02 CRV complete Brake Parts - brand to avoid, items to buy (eg OEM or not)
Old 03-05-2016, 05:18 PM
jojoringo's Avatar
Default 02 CRV complete Brake Parts - brand to avoid, items to buy (eg OEM or not)
2002 CRV Ex - original owner - ~ 100K.
Drive 5K year.
Light duty.
Stuck passenger rear caliper.
Assuming it really is - with PB / kroil etc and attempting rebuild - without many tools...
Going to do all of the rears - calipers, pads, rotors, hoses. And might as well do the fronts but not calipers.
I think Ive got a good idea how to do it all... but seeking a few suggestions on options around brand/part as well as paying someone to do the labor
rear rotors were turned 8/2012 at 80K. acquired new honda bought [I used to work at honda business office in atlanta and got stuff at 20% off] pads were installed then. that was the last turn on the rotors. to thin and now the heat with the caliper sticking its not worth f'ing with.
***any thoughts on a reasonable price for rotors/brand is appreciated ***
***same question for pads - was just going to buy the honda 'kit' with all the clips and guides and silcone package @$50 each*** even though it is cost more, it's complete and it's piece of mind - or is that not a real thing and I'm just paying extra for it? (it was a real things with parts for some of my other cars in the past to get OEM instead.)
Open to buying rotor/pad package
Open to buying caliper (semiloaded to get all the hardware)/pad package
Open to buying local or internet. I get the pros of a national chain incase we move from NJ to wherever and need to do a warranty swap. But wow the savings from Rockauto over Azone/Napa/Advanced/Pep is significant.
- Any brand or parts, to avoid?
- How low can you go price wise and get the standard performance as if it rolled off the line?
Inquiry #2 - Mechanic literally across the street will charge me $80/hourly rate (NOT BOOK RATE) to do the labor.
So, how long would it take an experienced person to do the above - with power tools - and a lift? 2 hours? Will he agree to a maximum amount in advance or is that rude and also causing potential upfront inflation on the time.
No warranty on the parts if you bring them to him and he is local only, but he has to be able to do it better and faster than me, right?
Time is money... and no running around to by jacks, stands, vac pumps, or bad back, torn knuckles etc. and then taking it apart if I do 1 thing wrong. I still have to buy it local or order it. Thanks for the opinions.
I gotta decide on parts (and tools) today so I have all I need (via shipping eg rock or local store) for next Tuesday when temp hits 65.
- Also did the reardiff back in 8/2012, 20K ago. should that be done again, now, even if no noise/clunking?
If you have links to step-by-step or some vids on the procedure - from hoses to calipers and proper cleaning/silicon grease and bleeding (given taking off the hoses all around), is also appreciated... in case I do the work myself or at least try to help the guy across the street (he wont rent me a bay after hours - but I had to ask if it was a possibility.). Thanks!
B_Swapped93
Suspension & Brakes
11
11-06-2018 06:16 AM
ODDeyeC
06-19-2010 08:01 AM
CivicSiDriver02
04-14-2006 10:17 AM
bigslimdog
10-26-2005 09:34 AM
deviant1
10-25-2005 06:48 PM
Quick Reply: 02 CRV complete Brake Parts - brand to avoid, items to buy (eg OEM or not)
