*Official H/T OFFROAD/LIFTED CR-V thread!*
#2101
Re: *Official H/T OFFROAD/LIFTED CR-V thread!*
Hey guys, I just picked up a 01 CRV. Its been ages since I updated my resources on the 1st gen CRVs but can someone update me and tell me is it best to buy springs or have a custom spacer/coilover set up? Are OME springs still the best lift springs around? Whats the most common lift brand/kit everyone is using today for their RD1s/RD2s?
Thanks
Thanks
#2102
Had some unfortunate luck New Years Day. Was driving home from the in laws and ended up driving through some downed power lines. It was dark out and a Truck had lost control and went off the highway and knocked down a power pole. We were the first people to pass and drove through 2 of the lines. The middle cable got caught under the vehicle and looped over the hood. Ripped my passenger side fender apart and broke the headlight. Also damaged the a pillar and broke my windshield with the top cable. Sparks were flying and the transformer exploded. Everyone in the V was unhurt but I think the V will be a write off. Not sure if I'll get another or move up to an Element.
Berz out.
Berz out.
#2103
Berz out.
Berz out.
#2104
Haha I don't think it would pass my Provincial inspection to be able to insure it. It might but they kind of ******** about it here.
Berz out.
Berz out.
#2105
#2106
#2108
Haha I dunno man I'm still debating. Elements are hard to find and I might just find another cheap CR-V and fix it up with the extra money from insurance. They gave me the option to buy it back from them for $500 so I'm gonna do that and have it sitting here. May turn it into a full off road play toy now or fix it and give it to the wife. We will see. If I had my old shop I would AWD a civic but alas no real good area for tinkering at the moment.
I haven't looked into Pilot's to much, not sure how much they are worth.
Berz out.
Berz out.
#2109
Hey everyone,
It's been an exciting day. I manage to get my wide wheels on along with some 15mm spacers. The CRV looks awesome but handles really bad. Wheels hops when accelerating in turns. Steering wheel been wobbling like crazy at hi-way speed. Some reason I got torque steer when accelerating from stop...
Does any of these happen to your CRV after lifting, installed wheel spacer, and wider rims?
I'm current setup:
-20mm front strut spacers
-30mm rear strut spacers.
-15mm hub centric wheel spacers
-15"X8" steel rims with 0 offset.
-215/75r15 street tires.
I'm planning to get some hubcentric rings for the spacers to the steel rims and hope to solve the wobble.
Let me know what you think!
I'm current setup:
#2110
Looks good. I would say 1. make sure the wheels are balanced. 2. Make sure your spacers are centered and the wheels are centered as well. Where did you get the rims from? A bent rim would cause a bounce and shake as well.
I'm not sure why you would be having torque steer is everything clear and nothing is binding?
Berz out.
Berz out.
#2112
Berz out.
Berz out.
The wheel spacers are hub centric to 64.1 and it fit really well, but I do need rings from the spacers to the rims. Having trouble finding 64.1 to 83.82... Any idea here I could find some?
I got the rims second hand. It looked straight when I was balancing them. I'll try to road force them next time. Good point man, I never would have thought of that.
I don't see anything binding. Every since I replace my spring(with oem) it started happening. I figure maybe being outside of stock height it would cause some pulls during acceleration. After installing these steelies, it was pretty bad. Do you think going from +50 offset to 0 offset would cause that? I know the car tends to toe out during acceleration. So with a more positive scrub radius would make it worse?
Any thoughts?
#2113
Finally got some snow in east TN. Of course we had to go on an adventure! Top picture is bad quality because of all the snow and wind. But you get the idea
#2114
I don't think it's a balance issue. I'll swap the back to front and see. Wheels balanced pretty good and I placed the heavier ones in the back.
Any thoughts?
Any thoughts?
#2115
yes I do! I'm sorry I just noticed this post. But with 2" front and rear the front is WAY taller. I actually removed the front lift and installed new struts. Left the rear alone and I like the look it gives now a lot more. And I still have plenty of clearance. The tires rub pretty good on full lock turns. But that's it.
#2116
Hey everyone,
The steering wheel wobble seem to settled down a bit. The torque steer was caused by slippery road and gravels on the surface. Still get a slight pull when accelerating but I think it's normal considering the +65 scrub radius.
I'm having trouble finding hub centric rings from 64.1mm to 83.8mm. If anyone know where I could buy some or possibly custom order some please let me know!!! Thanks...
#2117
Took about a week just to read this forum and man is it full of info. It's totally said and done that I'm getting cragar 8's but everyone is running 6mm, 8mm, or more. My question is 6mm the absolute minimum? I read a question on one of the previous pages asking if 5mm spacers would work and I was wondering the same. Anyone with 6mm spacers on the cragars care to pitch in how close the calipers clear and what the backspacing on your setup is? Recently picked up a '97 auto as the "new" daily. Needed something auto as I deliver pizzas and got tired of downshifting every turn in the integra, lol. Thanks in advance!
#2118
It's gonna be trail and error with the spacers. Mine didn't need much but I only had 1 or 2 mm clearance from rim to Caliper once the spacers were on.
Berz out.
Berz out.
#2119
I had some 5mm universal slip on spacers from auto zone and they worked perfect. its the caliper mounting bracket that rubs on the inside face of the wheel. I put the small spacer on and it took care of the problem. you do not need a big spacer to make the wheels fit as long as you have the low offset wheels. mine are 15x7 with a 4 inch backspace.
#2120
Well it's official. I pick up my 04 Element on Thursday. No more CR-V tuning for this guy. Time to move on to a different platform. Now I gotta learn all over again after just getting a handle on the CR-V stuff.
Is there an Element thread? lol
Berz out.
Berz out.
#2121
Hey why can't I post video it won't let me upload
#2123
Hey everyone,
I'm current setup:
I'm current setup:
#2124
Do any of you guys/gals have a picture of a set of larger tires on stock suspension? Looking to see if I like the look or if I want to pony up the money for the lift kit.
#2125
Hey everyone,
I went to my first novice TSD Rally with my crv yesterday. It was so much fun. Ended up getting lost and got hit with a penalty.
Getting back from the event got me thinking... Is there any way I can get more out of our 4wd system? Like have it running at all time?
If anyone know where I could get more info regarding this matter that would be awesome.
Also, I recall reading a post way back in this thread about lift ratio. In installed with the same spacer, the front tend to lift more than the rear. I think it was 140% front and 125% rear? If anyone remember the ratio please let me know.. Looking to get a bit more lift.
Custom made mud flaps and new 225/70R15 tires.
