ZEX nitrous on ZC motor. hook up witch to TPS ? which wire..
New User
ZEX nitrous on ZC motor. hook up switch to TPS ? which wire..???
I just finished installed a zex nitrous kit in an 89 hatchback with a ZC swap, then I went hook up the "spray" switch, I figured it was the Red/Blue wire. It wasnt, and it wasnt the yellow wire either and the Green wire is constant. So my question is how/where do you hook up the switch to the TPS.. Tried each wire at WOT... Cant figure it out. any suggestions ? I got it temporarly hooked up, but I dont deem it very safe.... Thanks
[Modified by WickedPerform, 6:22 PM 4/20/2001]
Re: ZEX nitrous on ZC motor. hook up switch to TPS ? which wire..??? (WickedPerform)
get a volt-meter and test which one is operating at 4volts of whatever it is
