ZC ( SOHC ) block/ Y8 head. What timing belt?
Old 09-21-2005, 07:25 PM
I'm a Jackass
julio_bOostamante's Avatar
Default ZC ( SOHC ) block/ Y8 head. What timing belt?
Well i did a little research but i havent come up with a definate answer. I did however find 2 opstions. Use the Timing belt that coresponds to the head, in this case use the Y8 timing belt. the other is to use the Z6 Timing belt with my Y8/ ZC SOHC bottom end.
Any answers to this question???
thanks in advance.
Julio
Old 09-21-2005, 07:27 PM
EFRue57's Avatar
Default Re: ZC ( SOHC ) block/ Y8 head. What timing belt? (julio_bOostamante)
you would get the y8 timing belt.
Old 09-21-2005, 07:30 PM
d357r0y's Avatar
Default Re: ZC (EFRue57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">you would get the y8 timing belt.</TD></TR></TABLE>
I'm a Jackass
so i cant use the Z6 belt? any reason? i really dont want to return the belt a 2nd time.
Old 09-21-2005, 07:33 PM
EFRue57's Avatar
Default Re: ZC (julio_bOostamante)
I don't know if it will work. I've always been told to use the timing belt that corresponds with the head. Now you can try it, but i make no guarantees.
Old 09-21-2005, 07:59 PM
I'm a Jackass
i found out that both the Z6/Y8 have the same amount of teeth (104)
so i guess i could use either. then again, the Y8 is like 20 dollars cheaper
rex714
04-30-2009 12:01 AM
one-cam
08-15-2008 08:11 PM
StupidSlowRSX
02-15-2008 03:00 AM
Y_my_91
11
12-06-2006 07:40 PM
CivicRaping
07-25-2005 07:47 PM
Quick Reply: ZC ( SOHC ) block/ Y8 head. What timing belt?
