ZC problem
ZC problem
Does anyone know any good info on doing timing belts on ZCs? Ive searched and searched every link I click on tells me to do something different, I've adjusted the timing on this ZC like 10 times and still its not acting right, only Codes I have are IAT and coolant temp sensors. It starts up idle is a little high but not too bad but when i tap the throttle rpms just drop like fuel cut off or something. Any suggestions?
Re: ZC problem (stivic)
do you need info on how to do a timing belt or a timing adjustment?
check out the zc resource
do a search for timing, there are a ton of threads on how to adjust timing and adjust timing belts.
yea TheZCR.com is the best place to find info for zc's
as for the IAT..clr the ecu and start up the car..if it comes on right away...
its just a broken sensor.
